yb timing belt scoring issue
anyone had this?
in the past ive had cosworths pick up a bit oil and you see a line of it on belt,but ive noticed an actual score in belt,and at a quick glance it looks like it might be a thermostat housing bolt rubbing off it
As Richie said above undo the tensioner & rotate it in the opposite direction which will move the belt away from the housing .
But if its badly scored i would replace the belt .
yeah thanks guys ive got a new belt,not chancing that for sure
so you think tensioner has slipped/fitted wrong?
i drove car 300miles home when i bought it and sat in garage since but going to be putting on road this year
when you tighten up the tensioner you can turn it both ways if you turn it anti clock wise it swings down towards the thermostat housing & rubs if you turn it clockwise it goes away from the housing which is what you want.
is it definately scored and not just the usual line down the middle of the belt(on the back)
as thats usual with them, it can make it look like somethings rubbing but its just the shape of the tensioner htat causes it
thanks andy il check this
jamie i know what your saying as iv seen that on previous cossies ive owned but this is def an indentation,cheers
borboyous
Aug 22, 2015 11:17 AM
