Painters??? Help needed!!!
Old Jan 1, 2013 | 12:56 PM
Garethw1986's Avatar
Garethw1986
Default Painters??? Help needed!!!
Hello ive just blown in the dog leg on the rear arch of my glacier white cav sri using holts spray, colour match is spot on but would you clear coat over the top?? Cars painted in high solid from factory and has no clear but will the spray paint be ok without clear?? Cheers
Old Jan 1, 2013 | 01:00 PM
davidfox280585's Avatar
davidfox280585
is it the mix to your code cans or direct shelf?
it should be ok to be honest,
normally if i do it i do it with gun,
i run it upto the little groove near the wheelarch on the cavaliers saves any blending
i would add lacquer anyway
Old Jan 1, 2013 | 01:09 PM
Garethw1986
It should be ok to be honest,
hi thanks for reply, yes its off the shelf holts paint, did not get it matched
Old Jan 1, 2013 | 02:59 PM
dingla rs's Avatar
dingla rs
Don't add clear coat it will peel off in time
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
