Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Ported head + Boost
Old Nov 3, 2003 | 12:50 PM
SapphyMike's Avatar
SapphyMike
Default Ported head + Boost
If you port the head, does that mean you have to run less boost because of the amount of air the engine can consume? more boost = more air sent mixed with the same amount of fuel = running lean?
Also would cams affect the boost pressure that you could run too?
Old Nov 3, 2003 | 12:52 PM
Ryan's Avatar
Ryan
no more boost
& more fuel
more air requires more fuel.
Old Nov 3, 2003 | 02:11 PM
SapphyMike's Avatar
SapphyMike
Old Nov 3, 2003 | 03:18 PM
SapphyMike's Avatar
SapphyMike
so 38 views, of which 4 were probably me n ryan, and no-one else bothers... hmmmmmmmmmm
Old Nov 3, 2003 | 03:19 PM
Rene's Avatar
Rene
ill stick to what ryan said
Old Nov 3, 2003 | 03:25 PM
SapphyMike's Avatar
SapphyMike
that extra bit at the bottom of ryan's post wasnt there earlier?
Old Nov 3, 2003 | 03:30 PM
Rene's Avatar
Rene
only have seen it with that
Old Nov 3, 2003 | 03:40 PM
Boost pressure DOESNT equal airflow, but people dont get that.
Cams and Headwork (and bigger exhaust housing, and loadsa stuff) does mean the car flows more air, so more power, at same boost reading, so yea, the car would need more fuel too.
Old Nov 3, 2003 | 03:43 PM
SapphyMike's Avatar
SapphyMike
so without the extra fuel, would the car run lean?
if the car was running 28psi on greys before the headwork, would it still be able to run 28psi or would you need to back the boost off to stop it leaning out?
PJay's Avatar
PJay
Surely a ported and flowed head won't increase boost, it'll smooth the air's path but if you running say 21psi and fueling for 21psi then surely it'll remain the same?
Surely porting and flowing the head only becomes an advantage when it can't flow the air that your trying to force through it!?
Also i can't see how cam's can affect the boost pressure that you can run either, but they affect power by managing the air flow in and out of the engine?
Surely the determening factors to the boost pressure you can rum are weather the head/exh/inlet/turbo can handle it and also wether you can fuel correctly for it and mainain sensible ACT's?
PJay
Old Nov 3, 2003 | 03:45 PM
SapphyMike's Avatar
SapphyMike
i dunno, hence why i am asking
perhaps Stu would be kind enough to answer?
Old Nov 3, 2003 | 03:49 PM
Surely its whatevers MOST restrictive?
Most the time its the turbo exhaust housing, but could be head, cams, manifolds, exhaust, anything.
But IMO once the most restrictive thing is made less restrictive then you got more airflow at the same boost level, so need more fueling.
Remember when Stu said about they needed to remove 10% or somthing of the fueling on Seans car when they went back to a mongoose from the 4" bore drainpipe he was running.
This is another "need Stu or Karl to confirm/explain properly" type post, as its hard to put into words.
Old Nov 3, 2003 | 03:55 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Bit of a contradiction there surely? If as you say cams manage air flow in and OUT of the engine, surely this is going to affect boost pressure, as it is air flow out of the engine that spins up the turbo .
Old Nov 3, 2003 | 03:58 PM
PJay's Avatar
PJay
Granted that may sound a bit wrong and i'm still learning all this stuff but surely if you've got your boost set to 23 psi no matter how much exhaust gas goes throught the turbo if the wasgate opens at 23psi then you get 23psi no matter how much exh gas is flowed?
PJay
Old Nov 3, 2003 | 04:01 PM
Mike Rainbird
Caraholic
Yes, but cams can / do affect at what point the boost comes in at...
Read my post, im right, the end
Old Nov 3, 2003 | 04:05 PM
PJay's Avatar
PJay
Agreed
This is what i was trying to clarify
PJay
Old Nov 3, 2003 | 04:07 PM
Karl's Avatar
Karl
Norris Motorsport
When you fit a ported head and/or cams it is wise if not essential to remap the car or at least confirm the fuel map is correct.
Lets take a cosworth mapped as standard by speed/densisty.
Based on a given rpm and map sensor input (i..e boost) (lets assume WOT) the car will be mapped for the engines actual airflow. This means we are saying that at X rpm and X boost the engine consumes X amount of air and hence requires X amount of fuel. This is fixed by the map in the ecu.
If we now fit a ported big valve head for the same rpm and map sensor output we are flowing more air due to the lower resistance the ports/valves offer to the air. The map will have X injector duration at this point which as it was specced for the std head will now be insufficient for the increased airflow at those same conditions resulting in the engine running lean.
On some engines the head makes little difference if say for example the turbo is the main restriction.
However if you take my engine capable of making 600bhp on 26psi at 7200rpm, imagine the consequence of putting in a normal 403 (grey's) map in. A normal grey map might have an injector on time of 16ms at 26psi@7200rpm and be sufficient to fuel for 380bhp. given my 600bhp potential I would be underfueling by about 35% with disaterous consequences!
so you see the answer is it's not about plenum pressures and rpm, its about actual airflow for a given plenum pressure and thats where ported heads and cams effect things and hence usually need remapping.
Old Nov 3, 2003 | 04:12 PM
PJay's Avatar
PJay
Another quality post, cheers mate.
PJay
Old Nov 3, 2003 | 04:13 PM
Told u
Stu @ M Developments's Avatar
PassionFords Creator
This is cool... im redundant on the essay front
Old Nov 3, 2003 | 04:16 PM
PJay's Avatar
PJay
Told u
I'll stand corrected in every way , if i did't ask or make suggestions/post ideas i wouldn't learn anything and that's what BB's are all about for me!
PJay
Old Nov 3, 2003 | 04:25 PM
I was pissin about mate, hence the on the end
Ok i was showing off too, lol
Old Nov 3, 2003 | 04:30 PM
PJay's Avatar
PJay
I know, i was just trying to get the last word
Old Nov 3, 2003 | 04:32 PM
Tough
Old Nov 3, 2003 | 04:34 PM
PJay's Avatar
PJay
Same
Old Nov 3, 2003 | 04:39 PM
Damnit
Old Nov 3, 2003 | 04:40 PM
PJay's Avatar
PJay
I'll give in, don't wanna run a other wise sensible topic
Old Nov 3, 2003 | 06:33 PM
Matt's Avatar
Matt
gwan karlos
jessie_rs
62
Aug 6, 2019 09:27 PM
Russ Payne
Sep 25, 2015 08:29 PM
caprixpack
Sep 25, 2015 07:53 PM
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
