Does any body on here no of any 1 that restores recaro seats out of my series 1
Looking for some 1 to restore my front seats out of my series 1 rs turbo as they are warn and I don't want to put different seats in it as I want to keep the originals
Don't ask - I don't know
To be honest mate if they need recovering you've got no chance whatsoever of getting hold of any of the cloth - that ran out years back. And if you do find some somewhere that someone has stored, you'll pay through the nose to buy it as people know what it's worth. If originality is what you want, you'll need to find a decent set of seats to replace yours.
Or do yours just need new bolsters etc and the cloth is fine ?
It's pretty easy to rebuild them from 2 worn seats and a good passenger seat or 2,I have done it loads and not just swapping the top halfs over so the winder is on the wrong side,I mean completely stripping the good bits from 1 and fitting to your frames.
The bit that sticks most folk is the headrests,there's a big r clip that stops them coming out,unclip the hooks between the top of the inside section of the seat and the outer and this reveals the r clips.
If you can do general maintenance to your car then rebuilding these is easy.
Had my 3i seat repaired when the foam had gone and started to flatten the cloth. Looked like new when he'd finished. Used a slightly firmer foam too and added a backing to stop it happening again too quick. Same with underneath where the support wires were cutting into the foam base.
If its just the bolster cloth thats worn, not the pattern stuff then any good trimmer should be able to match it from stock.
Kiran1600E
11
Oct 2, 2015 11:35 AM
muz
Sep 30, 2015 08:29 AM
SMILER258
Sep 28, 2015 09:04 AM
