Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
fiesta mk4 1.3 8v 1999 full engine convert
Old Dec 17, 2012 | 10:15 AM
jayreecelucy's Avatar
jayreecelucy
Default fiesta mk4 1.3 8v 1999 full engine convert
hey guys...
new to all this upgrades. i have a fiesta mk4 1.3 8v 1999 model.
has zetec wheels on and rest is standard. i want to pum an engine
in my car looking at a 1.7 puma engine or if anybody out there noes
a better engine to put in please say so. as iam new to all this
what do i new from the puma engine and what else will i need to get for
it to slip in and iam away. will be putting full springs and shocks to keep car handling up to scratch.... any think else you think i can do to my car. i.e show me websites with parts and maybe a step by step of fitting would be great if you have time. many thanks Jay
Old Dec 18, 2012 | 09:31 AM
ZsTone87's Avatar
ZsTone87
I've just done the Puma conversion and i can notice the difference in power, I had the 1600. Todo this i bought a Donor car. Pretty sure you need the Engine, ECU chip and loom, left hand mount, Mani and cat and MAF. It also depends on if you have a 2plug or 3plug loom. Sure someone else will quote me if I'm wrong. Hope this helps?
Old Jan 11, 2013 | 06:12 AM
Straight_4_N/a's Avatar
Straight_4_N/a
dont need the exhaust manifold or cat there all the same also the diffrence is easy to tell with the 2 plug and 3 plug you dont even have to look in the fuse box just look at you clocks and if the millage is digi then you need the engine bay loom from a digi puma 1.7 and if its in anglog then yep you gussed it you need a puma anglog loom. 9/10 on your cars year you will need the anglog loom from a puma 1.7 pre 2000 and a gearbox everything esle on the engines are the same bar the engine bay looms and gearboxs...
JoeyBoyden
Jan 4, 2024 02:36 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
Bobby9779
Aug 11, 2015 06:47 PM
lockie
Jul 31, 2015 10:03 PM
