DTC fault code D262?
Old Dec 12, 2012 | 09:06 PM
Mini-si's Avatar
Mini-si
Default DTC fault code D262?
Hi all,
My st170 is running like a bag of s#*t.
Have read the fault codes on dash and comes up with one code, being D262?
Have read its something to do with temp maybe?
But does anyone know what it means and the possible cause?
Cheers guys.
Old Dec 12, 2012 | 09:37 PM
RichieST's Avatar
RichieST
Disregard it. That's a dash board related code, it will not show engine DTC's, you'll need an OBD reader plugged into the diagnostic socket for that.
Is the engine management light on?
Old Dec 12, 2012 | 10:30 PM
Mini-si's Avatar
Mini-si
The engine management light came on yesterday and has now gone off again. The car has been hesitant for a good few weeks now. Found no fault codes on my OBD reader. That's why I tried the dash trick. Still yet to changed the fuel filter. Think ill do that before the fuel pump.
Old Dec 13, 2012 | 04:48 PM
The Underdog's Avatar
The Underdog
you cant fix stupid
imrc possibly?? i had no eml but the spring had jumped and needed a quick fix. run like a 1.1 when it was playing up
Old Dec 14, 2012 | 09:20 AM
Mini-si's Avatar
Mini-si
is there a way to check the IMRC, im pretty sure i have reciept of it recently being replaced by previous owner.( will check tonight) We've only had the car 2 months if that.lol
tankybaby66
Feb 6, 2016 02:24 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
Si B
Sep 12, 2015 06:49 AM
