Dry Sump Pump Belts?
Old Dec 6, 2012 | 08:06 PM
surrey_100e's Avatar
surrey_100e
Default Dry Sump Pump Belts?
Hi Guys,
Anyone know where i can get a dry sump belt, either custom made size or off the shelf?
Martin
Old Dec 6, 2012 | 08:49 PM
paulj's Avatar
paulj
Originally Posted by surrey_100e
Hi Guys,
Martin
i got mine from a local motor factors,about £5.00
cheers paul
Old Dec 6, 2012 | 08:53 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
just use a piece of string to "loosely" measure the size you need, plenty available, just ask for square or round teeth on the belt, whichever you require
Old Dec 6, 2012 | 09:17 PM
PAUL S's Avatar
PAUL S
Depends on the mesh of the pulley as to whether a motor factor will have one.
I bought mine from Titan.
Old Dec 6, 2012 | 09:33 PM
paulj's Avatar
paulj
i needed one approx 1" longer, titan never had any,it was them who recommended a motor factor.
cheers paul
Old Dec 6, 2012 | 09:38 PM
Cossie Sean
you dont need to do anything other than what i advised lads.......been there, done that..... many times!
Old Dec 7, 2012 | 12:14 AM
lacey's Avatar
lacey
L section ( square teeth as it was call) htd is round teeth ,
Old Dec 7, 2012 | 07:04 AM
ian sibbert's Avatar
ian sibbert
http://www.bearingboys.co.uk/Timing_...alculator-24-a
http://www.bearingboys.co.uk/Timing_Belts-1039-c
Old Dec 7, 2012 | 12:24 PM
surrey_100e
Cheers guys, i think ive found the one i need. Its the imperial L section pitch, with a width of 0.75" and 600mm long would be spot on, however i can only find them with a length of 609.60mm i guess i could space the pump away from the block to achieve this. Thought it would be too much to ask to be exact
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
20/20 vision
Sep 29, 2015 11:27 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
youngben
Sep 27, 2015 09:37 PM
