Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Please help me find out the cause of this...
Old Dec 6, 2012 | 07:01 PM
BenM508's Avatar
BenM508
New User
Default Please help me find out the cause of this...
Hi guys
Just recently ive noticed the steering on my Fiesta being a bit vague and very much lighter than it used to be, also, you can be going in a straight line with no change to the steering, all of a sudden the car will head off left/right, still with no change to the steering
This is accompanied by what can only be described as a knock coming from where the drivers side front wheel is, this is heard when going over bumps and when the steering is all the way over to the right and moving slowly, it doesnt sound like a driveshaft as ive had one go already and know what it sounds like
Any ideas?
Thanks in advance
Ben
Old Dec 6, 2012 | 07:59 PM
dug112y's Avatar
dug112y
passionford pro
Track rod end or bottom arm completely shagged would be first guess.
Old Dec 6, 2012 | 08:45 PM
RichieST's Avatar
RichieST
Yup, a bush or a ball joint has failed.
Old Dec 6, 2012 | 10:20 PM
martysmartie's Avatar
martysmartie
I would say a 'CV joint', or what has been said.
Martin
Old Dec 6, 2012 | 11:31 PM
BenM508's Avatar
BenM508
New User
Thanks guys, jacked the car up to try and see if there was any play, couldn't find any, will get it looked at very soon
Ben
Old Dec 7, 2012 | 08:28 AM
furry's Avatar
furry
DECODING JIBBA JABBA!!
Try the UJ at the bottom of the coloum.
Old Dec 8, 2012 | 02:36 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Try top mounts too, jack it up and try and push the wheel up, had a ka that needed one was fucking lethal when it caught the camber in the road
Old Dec 9, 2012 | 06:53 PM
BenM508's Avatar
BenM508
New User
After reading this about the camber I have to say, the steering changes depending on the camber of the road, car leaning to the right, have to steer to the left to continue straight, car leaning to left, have to steer right to keep the car straight, it didn't do that when i bought it
Old Dec 12, 2012 | 03:21 PM
BenM508's Avatar
BenM508
New User
Checked everything and the only thing we can find is play in the rack. This really annoys me when its a 2004 car thats got 84000 on the clock, last owner must have been pretty rough with the car because so far its needed a service, new wheel bearing after it collapsed and practically ate itself and the stub axle, and now the steering rack
mk3ste
Oct 17, 2021 10:09 AM
boeb
Jan 9, 2020 05:11 AM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
