Ford KA Discuss your Ford KA here!
Ford Ka rally car build
Old Dec 4, 2012 | 08:03 PM
Dan_c's Avatar
Dan_c
Default Ford Ka rally car build
Hi, new on here but your probably gonna see me on here a lot now. Just bought a standard ka(1300) endura, which is going to be built for the mull rally. My dad has a garage and has also done his fair share of rallies so were not total new comers but new to fords as its all been classic minis in the past.
Wanting some advice on
- brakes, iv beard mondeo brakes fit?
- gears, closer ratios an lower diffs?
- and also fueling, rejetting or using carbs, whos done what?
Everything else will be easy enough
Old Dec 4, 2012 | 08:12 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Mondeo brakes fit, you'll need the carriers, st170 discs, the carriers need spacing 3mm IIRC.
What engine are you intending on using?
Old Dec 4, 2012 | 08:27 PM
Dan_c's Avatar
Dan_c
What kind of mondeo? Is there a difference between the diesel an petrol etc. and were intending on using the kent engine thats fitted to comply woth group A so the box will have to fit that engine
Old Dec 4, 2012 | 08:38 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Mk3 are the one's generally used, petrol/diesel are the same.
In my opinion you'd be better off finding a set of throttle bodies from a bike, GSXR1000/R1 are what most people use but are getting dear because of that, plenty of other alternatives though.
You'll obviously need managment to run it, depending on who will be mapping it they'll have a preference.
Old Dec 4, 2012 | 08:50 PM
Dan_c's Avatar
Dan_c
I will be able to find some brakes easy enough then. Am i right in thinking the puma master cylinder is a popular upgrade to? The fueling is the last thing on the list to be honest, gonna be super busy with roll cages/fire etx/and wiring etc first
Are there any specialist uning companies? For mini parts i just use minisport but all i seem to find for the ka is body kits and chavvy bling lol
Old Dec 4, 2012 | 09:02 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I've known people to use 2.0ltr master cylinders, not sure I've heard anyone using the Puma one though.
Not really, for general stuff I'd be looking on Demon Tweeks, Burtons and Europerformance.co.uk.
Old Dec 4, 2012 | 09:24 PM
dug112y's Avatar
dug112y
passionford pro
as for the gears the 1400 puma box has good ratios along with a couple from your ka box with puma linkage. are you leaving open diff or going lsd?
Old Dec 4, 2012 | 09:58 PM
Dan_c's Avatar
Dan_c
Im gonna leave thr diff open as it makes it handle a bit better an a tad lighter. A ouma box might be worth looking into then cheers
JoeyBoyden
Jan 4, 2024 02:36 PM
matman
Sep 9, 2015 05:45 PM
Versus_Creations
24
Aug 5, 2015 09:32 PM
