Cosworth Ryan engine loom help/info
I have a fresh Ryan engine loom To Fit on my engine. The problem I have is the plug that goes onto the loom Inside the car.
Basically I have the plug end adapter ready to
Fit to ignition/fuel pump/ live feed etc. But I have no idea what wire does what, as the plug adapter that clips onto the Ryan loom has no wires in the end.
If anyone could help or has the wire code info for the ryans loom thanks.
Hello mate
. Okay thanks that might be very usefull to me, that part I need to look at will be on the interior someplace. Its the part that you plug all the wiring in the car to the loom. Ignition,fuel and feeds etc.
Yes, might be able to see the plug without removing the glove box as the plug is wired into the loom about there, just let me know when & if you would like to look
Thanks mate.
My instructions with my loom says this :
1/ ignition live. ( connect to black wire on main loom )
2/ water temp. ( connect to Brown/White white on main loom )
3/ tachometer/rev counter ( connect to Green wire on main loom )
4/ fuel pump ( connect to Black/Red wire on main loom )
5/ permanent battery 12v Live ( connect to Blue/Red on main loom )
6/ spare.
I've got the instructions here if you need a copy but you would need to check that they aren't different from your loom so I'm only quoting what the instructions from Car Looms UK supplied with my loom,
Stevie.
6/ spare.
Stevie.
Sorry to drag this up guys but need some info
I have a new engine loom but dont know who made it it has all the wires labelled but I only have 4 wires for the car loom
Tacho
fuel pump
water
ign
Thats all they say ok the 1st 3 are obv but only 1 ign what do I do about it?
Is it scrap now?
How do I know what wire on the loom to connect it too?
Tacho
fuel pump
water
ign
Is it scrap now?
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
