Tdic 2.2 st
Old Nov 30, 2012 | 06:41 PM
Brettski mk2's Avatar
Brettski mk2
Default Tdic 2.2 st
Hi well I just got a mondeo 54 plate silver 2.2 st 155 hp car is very good condishion and so cheap 300 pound
But..........my mate drive it in a flood and locked it solid. I removed the intercooler pipes and got a washing up bowl of water out removed the glow plugs and slowly turned it over on the crank with a bar it turned over ok so flicked the key and removed all the water from the cylinerd,put it back together and it started up
it sounds ok but there is a very slight missfire and more smoke out the back than i have ever seen so it has pobley bent a rod
So do I repair this engine or get one of the bay
Old Nov 30, 2012 | 06:58 PM
the_frozen_one's Avatar
the_frozen_one
Get one off the bay unless you know what you are doing and have deep pockets
Old Dec 1, 2012 | 03:06 PM
Brettski mk2
Well I left it running last night for a hour and it started it idle less lumpy so went for a drive to get some temp in to it and guess what the smoke has stopped and it drives well power is good too
so changed the oil and left it over night,popped down this morning and started the car and the smoke was back but not as bad
Drove the car 15 miles and no smoke?
but the old owner has told me that it has smoked for a few minutes before it went in the water
Could it be an injecter problem ?but no engine management light on and no smoke after 2 minutes of running
Think i'll get it compression tested first
What do you all think
Old Dec 1, 2012 | 03:18 PM
RichieST's Avatar
RichieST
Sounds good! The smoking can just be the EGR valve as mine used to smoke a bit before I blanked it off.
If it runs ok I'd be tempted just to use it, wouldn't bother sinking any money into it though in case it does decide to go bang!
Old Dec 1, 2012 | 03:45 PM
daviddunlop83's Avatar
daviddunlop83
Mine smokes a bit on first start up when cold. Soon as it warms up its 100%
Old Dec 1, 2012 | 04:37 PM
Brettski mk2
Mine is a bit worse than this but the same just falls out the exhaust
Old Dec 1, 2012 | 05:03 PM
RichieST's Avatar
RichieST
Could be a leaking injector?
Old Dec 3, 2012 | 11:42 AM
black_jack's Avatar
black_jack
Black Jack
Ive seen worse - run it how it is & just make sure you have your clean washing off the line before you start it!
you could try an ECU reset - sometimes helps (watch you don't loose your radio code)
Old Dec 3, 2012 | 08:34 PM
Brettski mk2
It really smokes for a mile when cold can't see behind me
Old Dec 3, 2012 | 08:38 PM
RichieST's Avatar
RichieST
Is it blue or black smoke? If blue then I'd worry, if black and it's only after startup then I would definately be looking at an injector issue.
Old Dec 4, 2012 | 12:43 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
If you've sucked up some water then you will have bent a rod - it's a very high compression engine! It's a clever car though and it can compensate pretty well for a bent rod!
Injectors don't really 'leak' as such, but they can smoke first thing for various reasons. If it's a load of smoke and sounds like a tractor, then it's one or more injectors. But if it puffs out a lungful of smoke and soon clears it's pointless tracking it down. I had brand new injectors, a new pump, rebuilt turbo, no EGR valve and it still smoked first thing!
Old Dec 4, 2012 | 06:55 PM
Brettski mk2
It's white/blue and stinks of fuel and stings your eyes
Old Dec 5, 2012 | 01:25 PM
DanW@FastFord
Spelling Club King!
Seeing as the car was so cheap I'd just carry on until it dies - as fixing it WILL cost more than the car cost you!
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
Adam-M
Aug 27, 2015 08:55 AM
Punter
Nov 22, 2009 12:18 PM
Stavros
20
May 20, 2007 07:06 AM
cossymad
Feb 16, 2005 09:37 AM
