Cosworth question
Old Nov 29, 2012 | 06:09 PM
adam151082's Avatar
adam151082
Default Cosworth question
Ok so im guessing im not the first person to ask this but i fancy upping the power on my 3dr Cosworth to around 400bhp with anti lag. Its a standard engine so im guessing i need
Injectors (color?)
RS500 intercooler
Group A fuel pump
Turbo (recomedations)
Set up
Is there anything else as im a bit clueless, what kind of price am i looking at for all the parts and set up? £2k?
Old Nov 29, 2012 | 06:13 PM
costina's Avatar
costina
Live long and prosper!!
T38 turbo
55lb siemens blacks for up to 430 bhp
wasted spark and closed loop software
Tuner of your choice
all the above
Old Nov 29, 2012 | 06:28 PM
charlie luciano's Avatar
charlie luciano
GT30/71 blower
Bosch 750cc injectors
spec r intercooler
MAD tinkering
Luciano
Old Nov 29, 2012 | 06:35 PM
costina's Avatar
costina
looking at nearer 3k tbh turbo being most expensive
Best advice is pick a Tuner and go with there recomendations
Old Nov 30, 2012 | 06:13 AM
adam151082's Avatar
adam151082
Sound like a good idea m8
Old Nov 30, 2012 | 06:27 AM
KSA-Cossie's Avatar
KSA-Cossie
T38 turbo
all the above
You'll need 83's with a t38 mate.
Old Nov 30, 2012 | 09:23 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Anyone happen to know how big are the Siemens 55lb and 83lb injectors measured in cc? The 55lb seems to be next step after Bosch Greys...
Old Dec 1, 2012 | 11:03 AM
martysmartie's Avatar
martysmartie
A decent HG, if you have not already!
The fuel pump should be ok I think, but you need to check the wiring or rewire it!
Why not go for 380 HP, this is achievable with a T34?
Martin
Old Dec 1, 2012 | 11:21 AM
Rsmat's Avatar
Rsmat
Mine runs just over 400 with a T34... On 55's.. You will need a 044 fuel pump for sure and re wire it to be safe.
All so HD wants doing.
Old Dec 2, 2012 | 10:14 AM
plynchy's Avatar
plynchy
Why do you want anti-lag?
Old Dec 2, 2012 | 10:26 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
You'll need a marem (spelling lol) shaft in the turbo to cope with the heat and modification to the iscv I think????
Old Dec 2, 2012 | 11:37 AM
Paul500+'s Avatar
Paul500+
just upped my spec from 400hp, i was running
L8 ecu
t34.63
siemens 55s
500 cooler
044 fuel pump
ABO7 inlet cam
free flow s/s exhaust
k&n cone filter
would go with a t38 over the t34 400hp on a t34 is really working the turbo flat out
if your going siemens 55s i have some for sale in the parts section these work fine with a t38 at 400hp could even go a little more if you wanted.
if you have the money to do it i would go 200 block longstudded for reliability with pocketed pistons
what ever spec you go for get a live map so its set up to your car
with 400hp 2wd i hope you can drive lol
Old Dec 2, 2012 | 04:02 PM
Rsmat's Avatar
Rsmat
Get ready for some drama's when it's 400bhp and same torque... When I let mine rip its a animal.
Old Dec 2, 2012 | 04:12 PM
Tarren's Avatar
Tarren
LOL! I bet it is
Old Dec 2, 2012 | 04:43 PM
opposite lock's Avatar
opposite lock
A breather system if not already done , map sensor and new underwear i imagine lol.
Old Dec 2, 2012 | 05:52 PM
Paul500+'s Avatar
Paul500+
forgot that one yes thats a must
Old Dec 2, 2012 | 05:56 PM
Paul500+'s Avatar
Paul500+
it will keep you on edge every time you drive it
when i did mine to 400hp first time out i went up a grass bank coming off a rounderbout, missed the lamp post and did no damage.
going for 500+ now, replacing the drivers seat for a toilet
Anutternutter
24
Aug 31, 2015 01:24 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Caddyshack
Aug 19, 2015 07:29 PM
cossie4x4
Aug 14, 2015 06:29 PM
Aug 14, 2015 07:29 AM
