fiesta Mk4 engine conversion
Old Nov 29, 2012 | 01:16 PM
Staity's Avatar
Staity
Default fiesta Mk4 engine conversion
Hey guys,
I am pretty new to the whole forum thing. My little 1.25 fiesta is on the way out. I had it as a first car and it has lasted 3 years. I was wondering if i decided to rescue my baby and get an engine conversion, Besides the obvious 'another 1.25 fiesta' engine what would be the easiest and cheapest to put in.
Any thoughts would be helpful and appreciated.
Cheers Guys
Old Nov 29, 2012 | 03:44 PM
gjh's Avatar
gjh
One of the following:
1.4 zetec se (mk4 si)
1.6 zetec se (from a zetec s mk5)
1.7 from a puma
they are the most straight foward ones, but if you have the cash and the skills
2.0 duratec from fiesta ST
2.0 zetec from momdeo or focus
1.6 cvh turbo from and escort/ firsta RS turbo
Duratec turbo from mk1 focus RS
And you are insane
Small block Chevy
4G63 from and evo
RB26 from a sjyline
2JZ from a supra twin turbo
Dodge Viper V10
Rolls royce merlin V12 from a spitfire WW2 fighter.
Old Nov 29, 2012 | 03:47 PM
gjh's Avatar
gjh
There was a feautre not too long ago in fast ford mag about converting a fiesta zetec s to puma power, think itys a very similar conversion for the mk4 can't rem,eber the exact issue but I'll find which one it is.
Old Nov 29, 2012 | 08:14 PM
Churtz's Avatar
Churtz
Im running a focus rs lump in mine silver top cam cover and inlet but it's a focus rs lump underneath
Old Dec 1, 2012 | 12:08 PM
Staity's Avatar
Staity
Hey,
cheers for your replies guys i will look in to this
Pete
Old Dec 1, 2012 | 12:40 PM
XR2000STEVE's Avatar
XR2000STEVE
for easy revvy power go for the 1800 zetec from the RS1800 or MK5/MK6 XR3i with a lsd turbo gearbox, as above mondeo 2.0 works well with the turbo box as well and sound mint on a set of bike carbs or twin 45 for serious bark.
steve
Old Dec 1, 2012 | 12:48 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Just go with a Puma lump, simple nut and bolt conversion, plenty of threads about it or get over to ZSOC.com.
2.0 is an option, but don't bother with carbs, we're not in the 80's anymore.
Old Apr 28, 2013 | 08:58 PM
Mk4 Rick's Avatar
Mk4 Rick
Hi mate did you have to mess about with engine mounts or was there one that fitted straight in?
Old Apr 28, 2013 | 09:07 PM
gjh's Avatar
gjh
Deffo need more pics of that one^^ looks awesome! Got a build thread for it anywhere?
Old Apr 28, 2013 | 09:15 PM
Mk4 Rick's Avatar
Mk4 Rick
Ive got a whole 2 litre mondeo car with the black top in it and want to no what mounts did you use and did the engine just bolt straight up
Old Apr 29, 2013 | 05:39 PM
Mk4 Rick's Avatar
Mk4 Rick
Im gonna use the mondeo loom.Gonna strip back whats not needed and throw it and transfer the loom to the fiesta.Im not sure on what clutch set up to use.Ive got a hydrolic set up with a front mounted starter,i was thinking a zetec 1.6 flywheel from the zetec e just not sure on what clutch to use
Old Apr 29, 2013 | 06:11 PM
fiestaphilwxm's Avatar
fiestaphilwxm
I too would like to know about mounts.
I guess your running an IB5 to use the original shafts and original gearbox mounts?
If not how did the gearbox mount fabrication go down?
Any pictures of the offside engine mount? Looks like a mondeo mk2/focus mk1 from the pics, but what does it bolt to?
Thanks, Phil.
Old Apr 29, 2013 | 07:31 PM
Mk4 Rick's Avatar
Mk4 Rick
Done some diging and found this.Im really interested to no what flywheel and clutch to use on the hydrolic gearbox that's in the mk4 fiesta
http://www.fiestaturbo.com/forums/my...0-07-vt140808/
Old Apr 29, 2013 | 08:11 PM
gjh's Avatar
gjh
That looks like a well nice mk4 there^ Thought I was the only 1 who liked them for a while.
Old Apr 29, 2013 | 09:14 PM
Mk4 Rick's Avatar
Mk4 Rick
Im after the fiesta escort zetec flywheel to fit on to the mondeo engine if any one has got one
Old May 8, 2013 | 07:40 PM
Straight_4_N/a's Avatar
Straight_4_N/a
Tip.
Zetec-E and Zetec-R are to diffrent setups and the little trick with the bellhousing used on Zetec-E dont work on Zetec-Rs as thay have diffrent bolt patens. Easly fixed you'll need to whole lower case from the zetec-e 1.6/1.8 and just replace the zetec-r lower crank case and sump with the 1.6/1.8 zetec-e.
Wiring wise for the fiesta rip the whole lot out but leave the tail lights and fuel pump wires there and just use the mondeo loom to run everything thing esle and just tap the fuel pump and tail lights onto the mondeo loom.
Old May 9, 2013 | 02:53 PM
Mk4 Rick's Avatar
Mk4 Rick
Ive got everything worked out apart from clutch and combination set up.im using the ib5 box with hydraulic clutch set up but dont no what set up to use.ive got a fiesta/escort zetec e 1.6/1.8 flywheel but i dont no what hydraulic clutch i can use and ive been told that a zetec s flywheel might work on the 2 litre blacktop but i need 100% confirmation of what i need before i spend any money.
Old May 9, 2013 | 05:34 PM
Churtz's Avatar
Churtz
Sorry for not replying I hadn't seen the posts!! Thanks for the comments!
I had to make an engine mounting point and used the Focus mount. Using an IB5 gearbox to use same mounts and shafts. Made a equal shaft bearing support for the long shaft.
It's running 220bhp and 250 ft/lbs at the moment, but got a new turbo exh housing to go on and remap... I'll stop at 270bhp I think!! Haha
Goes well.... Shocks a few people too.
Old May 22, 2013 | 05:01 PM
Ellis1990's Avatar
Ellis1990
i am also looking at doing something with my engine. since i decided to put the wrong oil in it for the past 4 years, so when i finally put the correct stuff in (and flushed it to get all the crap out) its decided to leak form every place possible. any tips?
JoeyBoyden
Jan 4, 2024 02:36 PM
Kirstiestar
Ford Fiesta
Aug 17, 2015 07:40 AM
A.t.p
Aug 15, 2015 11:37 AM
Rickyrustyfox
Aug 13, 2015 01:11 PM
knight19770
Aug 4, 2015 12:36 PM
