Help building rebuilding my fiesta mk4
Hello there guys,
So i recently i had and accident with my mk4 thing is i already fixed it but i'm thinking on rebuilding it i have seen some sick projects here and the projects i liked the most had this kit!
B-Tech Racing car
I think this are from a zetec s if i'm not mistaken but i would like to know where i can buy this parts and what kind of this should i consider doing
Thanks alot guys!
B-Tech Racing car
Thanks alot guys!
Ye thats a zetec s kit, it pretty much bolts straight on, but you have to shave a little around under the front lights. Have a look on ebay as there are always plenty of zetec s fiestas breaking, so getting a kit should be a piece of piss. As for what else? depends on your budget, can you afford to stick a puma lump in it? (pretty straightfoward), lowering helps, (40mm spring and damper kit, or coilvers if you can afford them), and decwent brakes are always a good move, pretty sure you can get mondeo V6 calipers with 280mm discs on there farily easily.
I dont think mk4 front end is that but with a bit for work it just makes its justice... about the engine you can talk to the pros here
You can never have too good brakes, but as you arte just stixking wityh looks, a decent set of discs and pads with maybe a better quality fluid will work wonders. I see quite a few people use ferodo ds2500 pads, never used them myself so can't say for sure, but I think they are a good "fast road" pad. As for other stuff, the ususal smoothing and de cluttering looks good, and you can pull the light unit apart and tint the headlight in black (or any other colour really), its easy to do, just pull the light unit out, strip the bulb etc all out, put it in the oven on a low heat to soften the glue so you can pull the unit apart, paint it and do it all again to re assemble. That fiesta you pictured has had it done. Aloys also look good on the mk4, ig you are on a budget, escort GTI or RS2000 MK6 alloys look good (but it won't be the most original mod).
) still dunno what engine maybe zetec turbo
