Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Focus Zetec starting problem
Old Nov 25, 2012 | 09:45 PM
d_jsr's Avatar
d_jsr
Default Focus Zetec starting problem
Hi Everyone,
Just registered to see if anyone had any suggestions for this problem.
The car seems to start fine but the revs are too low to keep it running & cuts out straight away. I've found that if I keep my foot pressed slightly on the accelerator for a couple of minutes the revs will eventually jump up & then work fine.
Seems to take longer for the revs to jump up if I haven't used it for a while, for example I haven't used the car since Wednesday & have just been sat in it for fifteen mins waiting for it to start properly with no luck.
Thanks in advance for any help.
Fordmad!
Sep 26, 2015 05:24 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
taylora1409
Aug 12, 2015 12:06 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
