4" mongoose or 4" scorpion ?
ive got a 4" mongoose on my series one all my mates with rs turbos are telling me i should get a scorpion because they roar more so which is better? has there been any tests in fast ford on series 1 exhausts for performance ? i dunno which one is better dont want to swap it over and find a drop in performance
Originally Posted by wildheart
Scorpions are too restrictive
my rs turbo used to have an 'old' scorpian system on it which was restrictive due to the sharp 90 degree bend at the back of the system. This snapped at the backbox a few weeks ago so I brought another scorpian. When it turned up I was quite surprised to see that all the welds had gone (I think there is 1 on the entire system) and the 90 degree bend has been better shaped like the mongoose so they are no longer restrictive. Its also 2.5 inch straight through the backbox as well !.........so scorpian arnt as bad as every one says
Duncan
Duncan
Originally Posted by Paul Ripley
Mongoose rock
, I have a scorpian on my Series one with a 4" tailpipe if you wanna swap
So everyone say stick with the goose
Originally Posted by RS-adam
Originally Posted by Rob84
3" bore mongoose all the way
Its not the bend on the scorpion thats the prob afaik its inside the backbox where it goes from 2.5inch down to about 1.5 or 2inch, had a pic where someone held a measuring tape up to one but cant find it. stick with the GOOSE or even Magnex!!! end of the day why change cos it sounds better when its performance that matters
I`ve got a 3" bore goose, but from the factory you only get the one type of back box wich is 4" inwardly rolled, and silenced, so i got the tail pipe choped of and got a 4" outwardly rolled pipe put on, and got the best of both worlds
I agree with Rallysport, even if mongoose did make a 4" Goose it would be overkill for a RS Turbo & the majority of Cossies
What mongoose do make are.......
2.5 inch systems with various diameter tailpipes including a 4"
3 inch system with 4inch inwardly rolled only.
These engines produces sometimes up to 250 hp and is a 1.6l, normaly. 2.5 is more than enough. When we're talking 3l, six sylinders, giant turbo and 1000 bhp, then 4" is needed. 4" on a RST is just unpractical.
WRC cars uses 2.5" exhaust. If it's good enough for Petter Solberg, is more than good enough for you.
oh dear, about a year ago i got a scorpion from the local rs breakers had a choice between a mongoose or the scorpion !!!!!!!!!!!! both 100quid each went for the scorpion as the price of the mongoose was cheaper in the mags new so thought i was getting a better deal
only to find out reading this that i made a bit of a twatful decision
wish i went for the goose too now
.only to find out reading this that i made a bit of a twatful decision
JK12
33
Apr 26, 2021 12:09 PM
