Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Reg plate lights , need help mot due !
Old Nov 22, 2012 | 09:48 AM
Lee-87's Avatar
Lee-87
Default Reg plate lights , need help mot due !
Hi guys and girls , the reg plate lights on my 53plate focus have randomly stopped working , changed bulbs checked fuses , checked wiring for breaks .... Nothing ?! Really need help as the mot is due on Monday :-/
Old Nov 22, 2012 | 10:10 AM
Jeff Collision's Avatar
Jeff Collision
Check every fuse in the car and make sure none are blown. Ensure that the bulbs are in good condition. Then check to see if the wire connection to the bulb in the tail gate is loose or disconnected. If so, get it fixed. If so, get it fixed. Also, you need to check for power and earth to the lights. If there is any rusty contact on the number plate lights, clean up the rusts.
Old Nov 22, 2012 | 10:40 AM
Lee-87's Avatar
Lee-87
Hi , no signs of any blown fuses , I've tried two new sets of bulbs , all connections are clean , rust free and not loose , only thing I don't have is a multimeter to check the power etc
Old Nov 22, 2012 | 10:43 AM
snoop69's Avatar
snoop69
Many,many moons ago reg plate lights were not an mot requirement but required by law. Check if they are still required. May give you a bit of time to fix if not needed on the day. *EDIT* just checked and they are required!
Old Nov 22, 2012 | 11:04 AM
Lee-87's Avatar
Lee-87
Just as I feared ill go have another fiddle on lunch break see what happens , thanks for your help
Old Nov 22, 2012 | 11:47 AM
furry's Avatar
furry
DECODING JIBBA JABBA!!
oi goatboy did you take the lamp right out and check the connections to the lamps?
i take it nothing came from checking the wires from body to tailgate?
have you got an old neon lamp or summit that you could plug into the car loom to check theres feed? and no i don't mean horse feed lol
text me if ya confuzzeled
Old Nov 22, 2012 | 12:01 PM
RichieST's Avatar
RichieST
Just making sure you are checking them with the lamp switch over to the right in either sidelight or dipped headlamp position and not to the left for the parking lights, as that setting does not illuminate the number plate lamps.
Old Nov 22, 2012 | 12:08 PM
martysmartie's Avatar
martysmartie
They are 100%!
OP, can you test the bulbs on a battery, as you don't have a meter?
I know you say they are new, but it may be they are getting blown etc when connected, you need a meter really or a test light, such as the bulbs once you have confirmed they are good, by doing as i say above, you can then verify you have power there.
Martin
Old Nov 22, 2012 | 02:05 PM
Lee-87's Avatar
Lee-87
All sorted , havnt had the car long I checked the fusebox under the bonnet , didn't realise you can take the glove box off and there's another fuse box behind it .... Was a blown fuses after all .... How embarrassing .... Thanks all for your help
3i Jim
Nov 20, 2015 05:12 AM
Mad_Mat
Alloy wheels and ICE for sale
Aug 28, 2015 10:03 PM
borboyous
Aug 22, 2015 11:17 AM
Graceland
Jul 31, 2015 10:34 AM
