Engine loom 4wd to 2wd
Formerly know as Puss
Guys i have a pectel style loom from a 4x4 saph which i want to put on my 2wd.
As far as i know its just a case of swapping the TPS and extending the wire for the temp gauge is that right?
Gary Krishna
TPS and the coolant temp sender as you said but the engine loom connects to the main loom behind the battery on a 4x4, not behind the dash like on a 2wd so you might have to extend some wiring.
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
muz
Aug 16, 2015 12:57 PM
