Cossie won't start
Old Nov 15, 2012 | 07:44 PM
zetec69's Avatar
zetec69
Default Cossie won't start
Currently rebuilding my cossie project and struggling to get it started now it's all back together mechanically.
Engine, sensors and wiring loom all from a running donor vehicle or new items.
Car has a toad alarm system fitted and new MSD fuel pump loom.
The problem is as follows - Turn ignition on, press keyfob to turn off immobiliser, crank engine and the car will try but has not actually fired up...yet!
I have checked the following and they appear ok-
Earth present at ECU pins
Fuel pump voltage present
Fuel at fuel rail
Fuel tank contains 20 litres of new fuel
Good spark on all 4 plugs
Firing order correct
All electrical connectors in the engine bay connected
Things I have looked at but still not confirmed 100% -
Crank pulley & sensor...after attempting to check the gap was around 0.6 - 0.8mm I noticed that one of the teeth on the pulley is smaller than the other 3, roughly 0.5mm smaller in height. Is this normal? The pulley and sensor both came off a running car I used for several weeks.
Suggestions Welcome!
Thanks
Brad
Old Nov 16, 2012 | 04:07 PM
LHD220Turbo's Avatar
LHD220Turbo
can you here the fuel pump prime? if not then that's the first port of call.
depending if its 2wd or 4wd, its not something simple like the cut of switch in the spare wheel well, that's often a common one that trips and prevents starting
Old Nov 16, 2012 | 04:43 PM
siscossie's Avatar
siscossie
3-door moonstone
Is there fuel getting in?
zetec69's Avatar
zetec69
Yep fuel pump priming and running as it should and cut off switch ok too. Going to recheck the timing later, I think it may be 180 degrees out.
Thanks
Old Nov 16, 2012 | 04:46 PM
zetec69's Avatar
zetec69
Yeah, the plugs are wet when you remove them.
Thanks
Old Nov 16, 2012 | 08:15 PM
zetec69's Avatar
zetec69
Sorted now, timing was 180 deg out, fired straight away once corrected.
Missed that sound!
orion88
29
Feb 16, 2016 08:47 AM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Bailes1992
Aug 16, 2015 07:14 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
