wood my l6 ecu be ok in my 4x4
Old Nov 14, 2012 | 06:06 PM
rickyg226's Avatar
rickyg226
Default wood my l6 ecu be ok in my 4x4
hi wood a l6 ecu be ok in a 4x4 cossie?
Old Nov 14, 2012 | 07:23 PM
opposite lock's Avatar
opposite lock
Its possible i suppose but its a downgrade from L8. Wont be a straight swap either as they work in different ways to L8 i.e throttle sensor.
Old Nov 14, 2012 | 07:33 PM
rickyg226's Avatar
rickyg226
its just a ecu i had laying about. i got my 4x4 as a rolling shell. i am using the 2wd inlet and throttle sensor ect
Old Nov 14, 2012 | 08:46 PM
costina's Avatar
costina
Live long and prosper!!
will be fine then
Old Nov 14, 2012 | 10:26 PM
The Youth.'s Avatar
The Youth.
you just need to swop 2 wires around on the TPS
I did this about 12 years ago whilst my L8 on my old saph 4x4 was being fixed
steve
Old Nov 15, 2012 | 12:53 PM
martysmartie's Avatar
martysmartie
steve
Not true, whilst it's correct you would need to invert the wires at the TPS, you would also need a PF01 TPS (Which OP has, so not a problem in this case)
Also you will no longer be able to run a knock sensor, and if OP's is YBG, (green cam cover) he will loose C/L.
Obviously you will need a calibration (EPROM) to suit as well, so no, it's not just a case of simply swapping the ECU's over.
Martin
Old Nov 15, 2012 | 07:51 PM
opposite lock
What loom will you be using L8 or L6? , as Marty has said if level 8 loom on 2wd ecu and tps switch the wiring (outer 2 wires) over . Plug and play if a L6 2wd loom.
Old Nov 15, 2012 | 10:58 PM
rickyg226's Avatar
rickyg226
L8 loom but all the in let and that r all off a 2wd
Old Nov 15, 2012 | 11:15 PM
rickyg226's Avatar
rickyg226
Thanks for all your help what wires do i need to switch ? If I just plug the l6 in will it still start up? I just want to get it running I will get a l8 soon
Old Nov 16, 2012 | 11:45 AM
opposite lock
Have a look here www.bigturbo.co.uk in the wiring section you,ll see the tps . pin 11 ,17,30. You need to swap 11 (ground) and 30(5v) at the tps itself.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
griffo69
Oct 4, 2015 11:58 AM
Iain Mac
Sep 30, 2015 09:39 PM
