brake warning light staying on!
Old Mar 8, 2005 | 04:46 PM
escortrsmatt's Avatar
escortrsmatt
Default brake warning light staying on!
on my S2 my brake warning light is staying on!it goes out when i disonnect the brake fluid level sensor but then the light doesnt come on when i pull the handbrake on!ps the brake fluid level is ok.any help appreciated!cheers.
Old Mar 8, 2005 | 04:47 PM
escortrsmatt
ps have changed the level sensor.
Old Mar 8, 2005 | 04:53 PM
rsnitrouskev's Avatar
rsnitrouskev
seen this prob b4 change the level sensor as mentioned above if that dont work take the bulb out ya clocks
Old Mar 8, 2005 | 05:18 PM
Stoo's Avatar
Stoo
I might be your actuall brake lines.My mates brike light was on in his Coss and we couldnt trace the fault,turned out his brake lines were corroded and seeping fluid
It wasnt much but enough to have the light on.Personally i wouldnt be happy untill i knew why it was staying on mate,must mean there is a problem somewhere and for some reason i think brakes are quite important
Old Mar 8, 2005 | 10:39 PM
AKRS1's Avatar
AKRS1
Try changing the level sensor sounds like its faulty mate
Old Mar 8, 2005 | 10:55 PM
radiant red's Avatar
radiant red
it is full, resovir that is ?
Old Mar 9, 2005 | 12:03 AM
bud-weis's Avatar
bud-weis
Football Cwazy
have you got abs, could be one of your belts is loose / snapped
Old Mar 9, 2005 | 09:39 AM
escortrsmatt
the level is up to maximum and yes i do have abs - would a snapped belt bring the warning light on??
Old Mar 9, 2005 | 01:31 PM
Stoo's Avatar
Stoo
I though if a belt snapped the ABS(Yellow) light would be on?
Old Mar 9, 2005 | 09:15 PM
bud-weis's Avatar
bud-weis
Football Cwazy
a snapped belt should bring on the warning light but i can't remember what colour it should be
Old Mar 9, 2005 | 10:00 PM
AKRS1's Avatar
AKRS1
yellow light would be on mate if belt snapped bcos its happened to me. Try new sensor
Old Mar 10, 2005 | 11:32 AM
KSA-Cossie's Avatar
KSA-Cossie
As above m8 mine was flickering then stayed on fitted a new sensor and it was ok.
Old Mar 11, 2005 | 10:40 AM
John Laverick's Avatar
John Laverick
Depents what year car it is...my D plate has a red light for the ABS
Old Mar 12, 2005 | 07:47 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
My D plate also has red light on the ABS belt. Get under the car if you can, the sensor may have fallen out. They only clip in & one of mine kept falling out so I eventually silicon'd it around the edges. B'cos both of them are the same (but one flipped over for the other side) one sensor fits on the top of the belt unit, the other on the bottom. It is the passenger side which is on the bottom & this was the one which kept falling out.
note: you MAY be able to see it hanging down, have a look behind the gearbox area on the passenger side. If you can see some wires with a small black box attached with a shiny metal clip on it, then this is the sensor.
If both of them are still in it could be one of your belts has snapped.
Old Mar 12, 2005 | 08:18 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
Here's a pic for you so you know what you are looking for & roughly where.
If it is the belt which has snapped:
RS build 01/86 - 10/88 code: 86AB 2M016AC
RS build 10/88 - 08/90 code: 89FB 2M016AA
Hope this helps ya & let me know once you've seen it.
yatta
May 21, 2016 10:31 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
