Pic request, 2wd Saff fuel sender
Old Nov 6, 2012 | 08:38 PM
GINGExR2 T's Avatar
GINGExR2 T
Default Pic request, 2wd Saff fuel sender
Has anyone got any pics of a 2wd Saff fuel level sender, from the top if possible
Ginger
Old Nov 6, 2012 | 08:54 PM
Phil2002's Avatar
Phil2002
Got these ones
Old Nov 6, 2012 | 09:15 PM
adam151082's Avatar
adam151082
Has anybody got a wiring diagram for these?
And what the wires for that conects to the little threaded stump?
Old Nov 7, 2012 | 07:32 PM
GINGExR2 T's Avatar
GINGExR2 T
Cheers Phil
Adam, the little stump doesn't have a thread does it, it's for the push on earth wire. I'm trying to figure out the wiring to see is i can use an XR3i/ERST sender unit instead of the cossie one in a one off tank for my project.
Ginger
Old Nov 8, 2012 | 07:23 AM
Doesnt a earth wire go on that stump.
Old Nov 8, 2012 | 07:20 PM
adam151082's Avatar
adam151082
Thanks Lads, but now i have another question im changing the fuel pump loom in my cossie and that Earth wire was joined (not by Ford) to the negative on the fuel pump wiring, can i just earth it or shall i conect it to another negative?
Old Nov 8, 2012 | 09:47 PM
GINGExR2 T's Avatar
GINGExR2 T
I striped my loom back earlier mate, and the push on earth wire is connected to fuel pump earth wire further back in the loom. Can't see an issue with taking it straight to a good earth.
Ginger
Kop2381
Aug 23, 2015 01:17 AM
borboyous
Aug 22, 2015 11:17 AM
Anutternutter
Aug 21, 2015 06:07 PM
mrmann
Aug 20, 2015 11:24 PM
marky_g
Aug 19, 2015 11:46 AM
