Stack speed pulse generator.
Old Nov 4, 2012 | 06:59 PM
jamie956's Avatar
jamie956
Default Stack speed pulse generator.
Looking for inspration on where/how to fit my speed pulse generator/sensor, any one fitted one.
This is being fitted in my mk2 cortina, T5 box 2wd front hubs.
I did read about somone doing a adaptor that fitts into the t5 speedo drive hole but havent found anything my self.
Old Nov 4, 2012 | 07:47 PM
stevieturbo's Avatar
stevieturbo
C**t
You can buy adaptors for speedo cables, Demon tweeks etc sell them.
Or you could fit hook up a toothed trigger off a front wheel or something and a hall sensor.
Old Nov 4, 2012 | 08:22 PM
scoooby slayer's Avatar
scoooby slayer
as far as i can make out mine runs of an abs sensor in the r33.
Old Nov 4, 2012 | 09:06 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i mounted mine on the alloy bracket for the front brake calliper so it read off the back of the 4 hub studs
you could probably knock something up if you on std calliers and clamp it behind the calliper bolts
Old Nov 5, 2012 | 07:43 PM
jamie956's Avatar
jamie956
Was thinking about the abs pick up on my 2wd hubs but not sure how many pick ups there are on per rotation, it might have to strip it down and have a look.
Old Nov 5, 2012 | 08:29 PM
stevieturbo
C**t
You'll need to check whether the Stack can handle a VR signal as opposed to a digital signal.
Not all ABS triggers will be suitable.
Old Nov 5, 2012 | 08:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if it's anything like my stack speedo, you only have to drive 2 miles to calibrate and it works out how many pulses relate to speeds. you do need to drive around 40mph though to keep it accurate though, but is within 0.5mph at 70mph, so pretty good indeed.
Old Nov 5, 2012 | 09:17 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
depends how new the dash is to do that and it has to be a digital signal will wrk with as little as 2 pickups just bond or tack some m6 nuts to the rear of the disk or something
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
Mc5506
Sep 29, 2015 09:06 AM
