BMW e46 problem
Old Nov 4, 2012 | 01:27 PM
cossie891's Avatar
cossie891
Default BMW e46 problem
On my other Halfs Beemer the number plate lights do not work I have fitted new bulbs and checked all the fuses in the glove box and they are all fine
A couple of days after fitting the bulbs the they started to work but now they have given up again so any ideas guys
Old Nov 4, 2012 | 01:57 PM
James @ M Developments.'s Avatar
Probably a broken wire on the tailgate shut
Old Nov 4, 2012 | 02:47 PM
cossie891's Avatar
cossie891
Great I hope not
Old Nov 4, 2012 | 07:18 PM
cossiestu's Avatar
cossiestu
The bulb holders have probably corroded / burned out, had that on mine...
Old Nov 4, 2012 | 08:22 PM
cossie891's Avatar
cossie891
I will have a look at them 2moro
Old Nov 5, 2012 | 07:41 PM
B16 Will's Avatar
B16 Will
its all about the 5 pot
Its a known issue for the bulb contacts to corrode on an E46. New item from stealer is circa £60.
Oranoco
12
Oct 2, 2015 02:18 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
