A/C Problem
Old Nov 2, 2012 | 02:28 PM
m@tt100's Avatar
m@tt100
Default A/C Problem
Hey guys,
my A/C seems to be on constantly when the blowers are on and set to cold.
Had a look at the relay and fuse and seems ok.
Compressor maybe?
Any suggestions are welcome!
Old Nov 2, 2012 | 04:27 PM
JOHNDQ's Avatar
JOHNDQ
Do you have the vents set to windscreen?
Old Nov 2, 2012 | 05:25 PM
dojj's Avatar
dojj
Resident Wrestling Legend
if you have it set to windscreen the ac will be on automatically
i had this problem when i got mine the first time around and couldn't figure it out
i felt like such a twat
Old Nov 2, 2012 | 05:36 PM
black_jack's Avatar
black_jack
Black Jack
Took the words right out of my mouth - about the AC coming on automatically when the vents are set to windscreen - this helps the screen demist faster, even in the winter, gives the AC a run as well (if the AC is mot used for a long time -eg through the winter- its bad for it)
Old Nov 3, 2012 | 10:08 AM
m@tt100's Avatar
m@tt100
Ha, no it's not on the windscreen, it is every setting with the A/C light on and off.
Old Nov 3, 2012 | 11:57 AM
dojj's Avatar
dojj
is it set to climate?
which mondeo is it?
Old Nov 5, 2012 | 07:08 AM
m@tt100's Avatar
m@tt100
Doesnt have climate. It's the Zetec S.
Old Nov 5, 2012 | 03:14 PM
dojj's Avatar
dojj
if it's the early mk3 then there is a flap reset you can perform
if it's any other then i'm not sure
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
