Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
ST 2.5 oil temperature
Old Nov 1, 2012 | 01:32 PM
Trevor82012's Avatar
Trevor82012
Default ST 2.5 oil temperature
My 225 ST's oil temperature is going up high when driving it hard.
At normal driving the temp is good
Can anyone give some suggestions why this is happening, I presume the oil cooler is failing.
Thank you for your comments.
Old Nov 1, 2012 | 10:57 PM
Thrustyjust's Avatar
Thrustyjust
Judging by where you live then air temperatures are higher, then the radiator is going to be working harder, as the oil cooler is fed from the radiator. 2 choices. Either fit a higher capacity radiator or an RS oil cooler, which is bigger.
Old Nov 1, 2012 | 11:08 PM
Karl 3dr's Avatar
Karl 3dr
I'd recommend an RS oil cooler, got one on mine and they do make a difference.
Old Nov 2, 2012 | 01:33 PM
Trevor82012
Thanks for the comments.
It was working fine before. Driving like I stole it, both Oil and water temps were fine.
Now when driving hard for for about 5 - 10 mins the oil temp starts to rise quickly then the water temp starts to go up.
I will change the oil cooler and let you guys know how it worked.
Cheers!
Old Nov 2, 2012 | 01:40 PM
Karl 3dr's Avatar
Karl 3dr
You're not getting oil in the coolant are you? Or the cooling system pressurising?
Old Nov 2, 2012 | 02:35 PM
Trevor82012
No oil and water is mixing. I checked that.
Old Dec 6, 2012 | 04:51 AM
Joeyford's Avatar
Joeyford
I know this sounds silly but I use the wrong oil, the higher grade in my st 2, the reason being is that its thicker and takes longer to break down, so basically I can drive longer and harder without having to put more oil in all the time. When the car went for a service at fords they even said its runs like new for an ST with 115,000 on the clock.
Old Dec 6, 2012 | 09:16 AM
RichieST's Avatar
RichieST
What grade do you use? Don't use anything other than 5w-30 or if it is moderately modified then 0w-40.
Old Dec 6, 2012 | 09:23 AM
SteveB's Avatar
SteveB
I'd be more inclinded to fit a proper oil cooler, as it's not a great deal more than a std RS cooler.
http://www.focusrsparts.co.uk/scc-sp...prod_1475.html
Old Dec 6, 2012 | 10:00 AM
Joeyford's Avatar
Joeyford
Yeah 0w-40 is what I use, it does make a noticeable bit of difference.
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
deathrider666
Sep 28, 2015 06:12 PM
