squeaking belts
Old Oct 30, 2012 | 11:37 AM
ADT168's Avatar
ADT168
Default squeaking belts
Hi,
people i know its a silly question, just thought id ask on here because its driving me mad,
when its wet/damp outside my alternator belt on my 2003 fiesta squeaks like mad,
is there any cans or penetrants i can buy to stop the squeaking,
any info appreciated
thanks
Old Oct 30, 2012 | 11:44 AM
Cossy Mike's Avatar
Cossy Mike
You can buy rubber lubricant in an aerosol but I think it's mainly for things like seals on windows etc.
spray a 'little' dashboard cleaner or something with a bit of silicone in it on the pulley and see if it takes the squeal away.....it will only last a few minutes.
DO NOT USE OIL (like WD40)
If it does I'd change your belt OR loosen the tension a bit, I'd say your belt are old and have gone brittle.
Old Oct 30, 2012 | 11:56 AM
adam151082's Avatar
adam151082
I heard talc powder.
Old Oct 30, 2012 | 12:59 PM
vroomtshh's Avatar
vroomtshh
Or chalk
Old Oct 30, 2012 | 01:37 PM
phil_focus's Avatar
phil_focus
Chances are the belt is old and needs replacing. They're cheap and easy to do so I wouldn't bother faffing with talk or sprays that only last 5 min.
Old Oct 30, 2012 | 02:05 PM
cossiestu's Avatar
cossiestu
Used to be able to buy a spray to stop squeaks, but not seen any for years....
As above, chuck a new belt on it and give the pulleys a clean while its off.
Old Oct 30, 2012 | 04:04 PM
saph4be's Avatar
saph4be
You can buy belt dressing but only a temp cure
Old Oct 31, 2012 | 09:28 AM
ADT168's Avatar
ADT168
ok thanks for the info ill have to buy a new belt then.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Nov 1, 2015 06:53 PM
dombanks
Sep 21, 2015 08:38 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
