15" ford rim- will it fit on fiesta st?
I want buy those rims for winter tyres. But I an not sure if they will fit on fiesta st brakes/calipers as they are 15" and have spokes which goes inside..so maybe it can touching caliper?
also this rim, will this fit 280 discs
Fiesta st have 280 mm, andI have fear that it can catch calipers with spokes (because spokes are a bit "inside" on first rim).
just for example, this rim (from google) have spokes which getting to inside, and can catch calipers if discs are bigger:
yes probalby we cant be sure if I dont try it :/ but rim is far away from me.
I think most 15" alloys will fit without any rubbing issues. I know that the Fiesta ST discs and calipers are the largest set that can be put on a Puma under standard 15" alloys without any need to shave the calipers.
He should be ok you can run those under the RS2000 15's too
JoeyBoyden
Jan 4, 2024 02:36 PM
vdun01
Ford Fiesta
Oct 5, 2017 08:14 AM
