Converting 2wd to run P8ecu
Old Oct 29, 2012 | 10:45 AM
B833YKJ's Avatar
B833YKJ
Default Converting 2wd to run P8ecu
When switching to run a P8 ecu with a 2wd loom do I just need to switch the TPS wires round on the plug to work with the P8 and pf09 TPS?
Cheers for any help
Old Oct 29, 2012 | 10:52 AM
costina's Avatar
costina
Live long and prosper!!
Yes swap the 2 outer wires on the TPS plug. depending on whos chip you will have to have a lambda sensor connected too.
This will help with wiring
www.bigturbo.co.uk
Regards
Paul
Old Oct 29, 2012 | 12:31 PM
B833YKJ's Avatar
B833YKJ
Ok thanks for the reply, I'll have to try and contact karl at NMS to find out. It's for an RS Turbo so plan to run one of his chips.
Regards
Dean
James Porter
Oct 28, 2015 12:17 PM
Oct 9, 2015 07:38 PM
FlashRS
13
Aug 31, 2015 06:02 PM
ray barker
Aug 7, 2015 09:00 AM
lockie
Jul 31, 2015 10:03 PM
