fitting sidedraughts on a mk2 escort
Old Oct 26, 2012 | 10:58 PM
pitman2k12's Avatar
pitman2k12
Default fitting sidedraughts on a mk2 escort
Hi i want to to fi twin 40 dcoe's to my mk2 escort (1700 x-flow) but the brake booster tower is in the way! I dont want to change the pedal box or remove the tower just yet i was wandering if something could be done to the tower to give me enough clearance for the carbs????
Old Oct 27, 2012 | 05:56 PM
orionmojo's Avatar
orionmojo
Unbolt the brake servo where it goes through the inner wing, and loosen the bulkhead bolts. The bracket that strengthens the inner wing will pivot 180 degrees on the bottom bolt , drill a new hole and re bolt it into position. This should lower it about 2 inches
Vincereese
Jun 1, 2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
steerfromdarear
28
Jan 29, 2016 06:14 PM
3i Jim
Nov 20, 2015 05:12 AM
Vincereese
Aug 16, 2015 06:38 PM
