Mondeo mk1 Airbag
Old Oct 26, 2012 | 07:42 PM
fordy70's Avatar
fordy70
Default Mondeo mk1 Airbag
Hi,have a problem with my airbag light on all the time on my 93 mondeo,it just has a air bag on the drivers side with no seat belt pre tensioners! Changed the air bag,clock spring,module but light still on!Checked the fuse (fuse36) thats fine with power,the thing i cant work out is there is permanent live at the fuse but at the pins going into the module it is powered by 3of the pins when you turn on the ignition,there is no permanent live,is this right? Does anyone know what pin does what,i cant find a wiring diagram which tells me,not sure what else it can be,the light is on all the time
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
Tank Mike
Sep 26, 2015 08:07 AM
