PLX Devices OLED Boost Gauge
DM-100 (52mm) display with display module and Boost sensor module.
Basically it's an OLED screen that's set in a traditional 52mm gauge housing. They're very clear and very accurate.
Each gauge can be connected to multiple sensor modules. For example, you could add an oil pressure SM to this gauge and it would display both without cluttering the dashboard.
Obviously they're fully customisable - just plug your computer into it and you can edit anything you like. Gauge styles, units, range, backgrounds, colours etc.
More info at www.plxdevices.com
Looking for around £200 delivered
Offers welcome.
Yeah you need each sensor module. I have a friend who is a dealer for them - rough prices are:
AFR £140
EGT £80
Fluid Pressure £90
Fluid Temp £70
Air Intake Temp £80
All prices include the sensors and waring harness etc.
AFR £140
EGT £80
Fluid Pressure £90
Fluid Temp £70
Air Intake Temp £80
Sorry to sound thick! But what's the difference between yours, an the bran new plx device gauges on eBay that say you can add upto 32 different sensor modules to them an display them all on the one gauge? Cos they can come with the boost sensor module like yours, but at £140 new delivered?
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
