Escos intercooler
Old Oct 25, 2012 | 06:42 PM
matsin's Avatar
matsin
Default Escos intercooler
How much power can i run with a orginal escos intercooler? Thinking about making the engine bay standard looking again.
Old Nov 2, 2012 | 01:22 PM
matsin's Avatar
matsin
anyone?
Old Nov 2, 2012 | 01:29 PM
manoj's Avatar
manoj
Originally Posted by matsin
anyone?
i would have thought Stage III power, 330hp would be ok with the EsCos i/c.
thanks,
Manoj
Old Nov 3, 2012 | 05:55 PM
matsin's Avatar
matsin
thanks,
Manoj
i think so too, but i would be great if it could cope with 400hp
Old Nov 16, 2012 | 11:53 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
I reckon it'll be able to run 400bhp, but its always better to have bigger IC at that point to have lowest possible inlet temperatures.
Old Nov 17, 2012 | 07:31 AM
Bart's Avatar
Bart
Make a seperate chargecooling system instead of the engine coolant. Use a small electric pump and radiator. This will cope with 400bhp.
Old Dec 5, 2012 | 05:28 AM
matsin's Avatar
matsin
thanks guys!
Old Dec 6, 2012 | 04:47 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Assuming regular 25°C ambients in the summer, then Stage III is the limit without separating the charge-cooling arrangement from the cooling system to a stand alone set up. 400bhp is then the limit if separated, but you will still see the map retarding the ignition in really hot weather (above 25°C).
If the car hasn't got aircon, then an RS500 style intercooler would be best.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
