small turbo escort cossie loom conversion
hi guys n girls just started to convert my small turbo escort cosworth to l8 management i bought everything new includeing a new big turbo loom just cut all the caseings of my original loom hopeing to remove it but looks abit harder than i first thought? has anyone done this if so what did you do ? and does anyone have a pinout of original eec-iv ecu cheers
I believe most guys just leave the small turbo loom in place and add a 4x4 L8 ecu loom to run the engine, leaving all the other small turbo stuff intact. As already suggested, get over to the Escort forum quick!
Hi mate I am just in the process of converting mine at the moment the easy option is to have a loom made to suit i.e. for wasted spark 02 sensor etc. and leave the existing ford loom in place you can remove the engine loom completely just unplug it from the two large multi plug on the N/S inner wing. I wish I never start it now I am up to £3500 and I still need to buy a chip and get it mapped.
Hi mate yeah I looked into couple of different ways you spent a lot I spent £1000 and that's everything except 250 for a chip and live map set up i fitted brand new loom only 385 delivered and bought complete dizzy brandnew leads group a coil 3 bar map l8 Ecu air +coolant sensor throttle body complete with pf09 Tps crank pulley and sensor knock sensor genuine plugs I will upload some pics tomorrow I have removed complete engine loom which took a day once I had wire diagram has been a doddle only kept 6 wires and she will run which is rev counter temp gauge oil light fuel pump earth wire live wire and lasty ignition feed .cheers
Yeah mate I know I hope my wife doesn’t find out how much I have spent and still have to spend. I have bought the MSD coil pack conversion as I did not want to go on to a dizzy. I have also bought a new t34 .63 turbo, a radtec intercooler with radiator so I can keep the air con, a set of Siemens 55 black injectors and a Kent AB07 inlet cam I am hoping for the 400bhp mark.
You did well to get a throttle body with PF09 TPS I had to pay £130 as they are like rocking horse s**t
Haha I no the feeling oh right ok I didn't want to Realy go dizzy but I hope buying everything brand new I won't have to many problems I'm looking for about 350 on my hybrid t3 then later next year get a t34 and go for the 400 bhp
yeah took me a while to get hold of my pf09 didn't realise how rare they are will up load couple of pics of the wiring I'm removing .
its not that bad when you have wire diagram so you no what goes where its ok because you only need to keep rev,temp,oil light/gauge/ in the engine loom then connect fuel pump and she runs so i kept 4 wire from engine loom and cut out 56
and she runs perfect first time now for trip up too blackpool to msd on the back of my vivaro 400 mile round trip and cannot wait
I’m away at work at the moment so progress on mine has stopped and it will be Christmas time when I get home next so I will not have time to work on the car, it will be about February time before I get back on it
. My new intercooler arrived and wiring loom so I have nearly all the bits I need now. I wanted to keep my air con so I had to get one off front pulley made. I just need to get a new fuel pump and some other bit and bobs and that me ready for MSD and 400bhp hopefully
. When you going to MSD? I im quite lucky MSD is only 30 miles away from me.
Yeah I no the feeling it's hard to find the time I'm a mechanic by trade but the time I finished get some dinner it's 7.30 already and with Christmas and stuff hard to find the time but from the sounds be worth waiting and taking your time in the long run took mine out today and its running perfect only got a stage one chip init that came with the Ecu and boost holding 15psi but it feels so much stronger on the road than before I am going to call tomorrow and see when they can fit me in
i feel like a child on Christmas morning again
Billy_RS
16
Oct 11, 2025 09:41 PM
muz
Aug 16, 2015 12:57 PM
