Loose distributor
Old Oct 21, 2012 | 09:46 PM
tkracing's Avatar
tkracing
Default Loose distributor
Is there a nut holding this from moving,
and I believe the sensor connector should be around the5 o'clock position....
And would this change timing? If it wasn't exactly in the right place?
Set crank pulley to tdc, then check rotor arm is through/ in line with the notch, .... Is this right? And how do I get the distributor spot on?
Old Oct 21, 2012 | 09:52 PM
fraser9764's Avatar
fraser9764
Iirc there is just a bolt and plate at the side of the dizzy housing into the block that lock it in place. You are setting tdc to the groove on the crank pulley not the CPS lug?
Old Oct 21, 2012 | 10:03 PM
tkracing's Avatar
tkracing
If the crank is at tdc , and the distributor moves this will affect timing, won't it?..... The spark won't happen exactly when it needs to?
So, do you set the dizzy up with crank at tdc then if timing needs tweaking do it from the crank
TPM961
Jan 15, 2018 10:50 AM
20/20 vision
Sep 29, 2015 11:27 AM
pabloXR
Sep 21, 2015 12:42 PM
landaqmabba
Sep 15, 2015 07:16 PM
dms04
Sep 11, 2015 01:57 PM
