fuel computer
Old Mar 7, 2005 | 09:23 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
Default fuel computer
ello peeps
ok my erst has a fuel computor (on the d plate too, didnt think they could have it) neways, its reads perfect and ive grown quite attatched to it now cos it is much more reliable that the gauge and also i save loads of fuel if im on a journry too just knowing whats goin on helps loads
neways im breakin the old girl up and just bought a rs turbo 4 dr estate and what to fit the fuel computer, can ne1 tell me where the sensors and all the bits i need are and also is there a way of resetting it without disconnectin the battery??, cant get my hand up thru the vent to pull the plug but want to reset it to see what mpg i get on a run sometimes (avg mpg)
so in short
1.where are the sensors wires and stuff to fit a fuel computer
2. how can i reset without takin the batt off (some sort of hold this and press that maybe????)
and
3. how come my d plate has a FC ??, all fitted as per ford and she aint a later ringer cos the floors and the tags are all propper
fitting the interior out of my breaker rs this weekend so wanna change over fuel comp and dash etc etc while im at it
cheers
Old Mar 8, 2005 | 06:25 PM
1.9 xr2 on 40's
st170 breaking
come on ppl, i know i need the pipe off the meter head, what else?
Old Mar 8, 2005 | 07:28 PM
Andy-R's Avatar
Andy-R
there is also a plug to the gearbox if i recall correctly and a plug to the fuel tank which sits just under the rear seat.........hth am sure someone will correct me if am wrong.
Old Mar 8, 2005 | 07:30 PM
1.9 xr2 on 40's
st170 breaking
cool so it shud just be the fuel pipe with sensor, speed sensor out of the box and the bit out the tank then
bonus cheers mate
Old Mar 9, 2005 | 12:53 AM
rs_daz's Avatar
rs_daz
I hate looking at mine seeing 22mpg popin up
Old Mar 9, 2005 | 05:05 AM
JesseT's Avatar
JesseT
It has a reset button in the front panel.
You need to move over the display, fuel computer loom, speed sensor from the gearbox and the fuel flow sensor from the fuel distributor.
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
