zetec oil breather
Oct 20, 2012 | 10:44 AM
zetec oil breather
does anyone run a aftermarket oil breather or catch tank on a zetec engine, if so wot and how hav u done it?
is the standard set up just crank case breather round to rocker cover?\
cheers
Oct 20, 2012 | 11:57 AM
the standard breather is piped back into the air intake . just fit a tank and put both of them to it and vent the tank to atmosphere.
i'd post a pic of mine but its a little different to the norm with it being dry sump.
Oct 20, 2012 | 05:50 PM
Quote:
Originally Posted by
crazycage
cheers but im running carbs so how do i go about that now? where will the rocker cover one go?
Oct 20, 2012 | 06:09 PM
Makes no difference mate, just run the one from the front breather on block to pot and rocker cover to pot, then pot to atmo
Oct 21, 2012 | 08:12 PM
Oct 21, 2012 | 09:18 PM
I'm building a zetec turbo, and I'm hoping to plumb it in in the same layout as my cvh turbo unless I'm advised otherwise, using a bailey breather btw
Oct 22, 2012 | 04:00 PM
studabear
that what my initial plan was but wanted confermation, seems all is well to proceed!!!!
Oct 22, 2012 | 06:24 PM
primey
cheers
I ran a catch tank from the rocker breather, then back into the breather (snapped the k&n bracket, hence excuse the cable ties)
TPM961
Jan 15, 2018 10:50 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Chopshop85
Sep 18, 2015 06:13 AM
talon1
Sep 15, 2015 10:27 AM
BRAM
Sep 8, 2015 07:11 AM
