My Series 2 RST Project
Old Oct 19, 2012 | 08:34 AM
chalkey's Avatar
chalkey
rst junkie
Default My Series 2 RST Project
Thought i would share with you guys my new project, ive been away from fords for a long while but always had a soft spot for them
ive always loved these and being 30 this year i decided i needed an early birthday present to myself as at the second all i do is build cars for other people i wanted another for myself, so here she is
currently has a turbo problem but that doesnt bother me as they are easy enough to change and i have a hybrid one availible, also has lots of electrical grimlins that need sorting but over all its in very nice condition that ive seen so far just needs a damn good steam clean and silly bits sorted
so far ive ripped all the interior out to clean it all up and pulled the cage out (its forsale btw so pm me if you want it) dash it to come out next to pull the crappy clifford out and find out what goes where wiring wise
from what i can gather this car has been very much one owners pride and joy but with alot of cars like this the last owner just didnt seem to care about it that much. but this is where i come in to restore the balance
if you used to own this car id love to hear from you or know who owned it, as the listing had next to no info atall on it so was massivly undersold in my honest opinion, saying that ive yet to really pull it apart so horror storys may be lurking
ill update this as and when the wife lets me get on with it
Old Oct 19, 2012 | 09:13 AM
Stu_K's Avatar
Stu_K
I saw this on ebay. I wondered how good/bad it was.
You've not hung around.
I'll be watching this thread.
Old Oct 19, 2012 | 09:34 AM
chalkey's Avatar
chalkey
rst junkie
honestly from what ive seen its very good so far
has a nice full width fmic aswell which the add didnt mention also came with a load of parts aswell, inc a spare bottom end
engine sounds sweet aswell
Old Oct 19, 2012 | 09:51 AM
mr west's Avatar
mr west
cool, i'll be keeping an eye on this thread
Old Oct 19, 2012 | 09:52 AM
Carlos-Titx's Avatar
Carlos-Titx
Love RS turbos. Be good to see the work on it.
Old Oct 19, 2012 | 09:55 AM
chalkey's Avatar
chalkey
rst junkie
ill be updating as i progress with it and highlight what i find
Old Oct 19, 2012 | 11:03 AM
foxy06's Avatar
foxy06
Also saw this on the bay, looked a good buy from pics and if it only needs turbo replaced!
Old Oct 19, 2012 | 11:42 AM
chalkey's Avatar
chalkey
rst junkie
only thing thats really annoyed me is they left the cage in loose rattling around so its wrecked the drivers rear doorcard so need to find one of those
Old Oct 19, 2012 | 12:50 PM
Tonyt1t's Avatar
Tonyt1t
Grey Mk4 Early XR3I
Looks lovely mate i miss my black one
Old Oct 19, 2012 | 04:10 PM
Smithy23's Avatar
Smithy23
good luck with it all hope all goes well
Old Oct 19, 2012 | 09:27 PM
chalkey's Avatar
chalkey
rst junkie
Thanks guys, every time I look at the thing I smile
Picked up my brand new hybrid turbo today, just need to order the return elbow then its fitting away and then see how it runs.
Old Oct 20, 2012 | 08:06 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Looks like a nice one mate!
Old Oct 20, 2012 | 08:45 PM
chalkey's Avatar
chalkey
rst junkie
todays update
ripped the dash out, got the turbo of (was well shot) also found the oil return was well knackered
old t3 v's hybrid t3
can someone tell me if this should have a vacum line connected?
also on the top hose what should the little t off connect too?
Old Oct 20, 2012 | 08:54 PM
chalkey's Avatar
chalkey
rst junkie
also can someone tell me if the oil return union that goes into the block should be a push fit like the pic below or should it screw in, its been modified aswell so maybe this is why the return split
Old Oct 20, 2012 | 10:00 PM
davidfox280585's Avatar
davidfox280585
oil return should be pressed into the block,
sure the vac pipe is for fuel pressure may be wrong though
the top pipe is the water feed for the turbo not needed as long as the rad one is also blanked
Old Oct 20, 2012 | 10:48 PM
chalkey's Avatar
chalkey
rst junkie
yes on the left hand side of the rad, thats blanked too
thanks mate, yea it looks like the fuel pressure regulator
Old Oct 21, 2012 | 11:15 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
someone correct me if im wrong but my s2 has never had a vac pipe running to that regulator in the picture and ive not come across one that has before.
Old Oct 21, 2012 | 11:27 PM
chalkey's Avatar
chalkey
rst junkie
To be honest it doesn't look like its ever had anything connected to it, so you may well be right
Old Oct 23, 2012 | 09:32 PM
mk1trb's Avatar
mk1trb
Boost Junkie
that pipe has nothing going to it, dont worry peoples. nice looking s2 mate. if thats a ebay t34 you'll need a 5mm spacer so the compressor housing clears the block or you coud put the t3 compressor wheel and housing on it, be the same as a stg3 turbo in theory
Old Oct 25, 2012 | 12:22 PM
chalkey's Avatar
chalkey
rst junkie
cheers mate, any idea where i can get said spacer from
Old Oct 31, 2012 | 03:47 PM
0150carmac's Avatar
0150carmac
looks like you got yourself a pretty good turbo keep up the good work
Old Nov 14, 2012 | 08:57 PM
chalkey's Avatar
chalkey
rst junkie
ok bit of an update
been stock piling bits for it
nomad pillar pod will house my mocal boost gauge, twins custom dash pod will house my mocal dual gauge (oil temp and oil pressure), alloy airtec rad, digital volt gauge to go in centre console
so now i need to get it all fitted and run the car up to see what im working with, im moving the car to my workshop in the next few weeks so will be able to get on with it a little better with the correct tools which always helps
a question for you guys. the car had twin cooling fans on the front of the intercooler, will this be man enough or should i be trying to run a sucker fan on the back of the rad or put the fans directly on the front of the rad and move the intercooler forward? i will be running a kenlowe fan controller aswell
Old Jan 2, 2013 | 09:30 AM
chalkey's Avatar
chalkey
rst junkie
ok so drove the car for the first time over the chrismas break and to be honest its abit of a pig at the min
Jobs to do from memory
Find a new tailgate
Sort wipers as they wont park without having a jerky spazim
Bad earth on the headlights
Engine breathing real heavy (think this may be a typical cvh problem tho)
Got a really bad cold start problem asin it will flatten the battery before it fires – doesn’t do this when sitting in the garage which is odd
Generally runs abit poo (getting it setup and rolling roaded will fix this I hope
Find out why it will only boost to 5psi
Fix the steering column as all the bushes seem busted
Replace both electric window motors or recon them or rewire the whole lot to make sure the loom isn’t at fault, (apparently a common problem)
Fix the door cards and the rear seat base
Rewire the rest of the car to make sure all the bits and pieces work as they should
Remove the front abs system as its pants
convert to mk3 mondeo front calipers and st170 discs
Sort the rear brakes as they don’t work atall, going to convert to 2wd cossie rear disc and re plumb the sytem so i can run a bias valve for the rear
Only a little list
some new pics
Old Jan 30, 2013 | 10:17 AM
chalkey's Avatar
chalkey
rst junkie
Default now going efi with ofam
small update on this
now going down the efi route, ordered an ofam from rob @boostmonkeys and orderd an wideband innovate kit from burtons so i can have the ecu run in closed loop mode so it will self tune (well thats the plan anyway)
collecting most of the parts needed to carry out the conversion tomorrow
pulled the old head of to find a bit of a lip on the bore of the block but the compressions were all 10 bar so not sure to do about this at the momeent
im going to drop the engine off to my engine builder and see what he says, i have a spare block aswell so will take both and go from there
now have st170 discs and mk3 mondeo calipers and pads so thats a job to have a look at on the weekend if i get a chance
Old Jan 30, 2013 | 11:22 AM
Nice project.Im not that keen on black wheels though.
Old Feb 24, 2013 | 07:51 PM
s23rta's Avatar
s23rta
let us know how the fitting of the mondy brakes go. bought my self a black s2 today
Old Feb 25, 2013 | 08:24 PM
wRenRox_S2's Avatar
wRenRox_S2
nice looking project keepin an eye on your progress
Old Apr 5, 2013 | 03:52 PM
chalkey's Avatar
chalkey
rst junkie
started fitting them last week, got some 12mm spacers off ebay that helped and the longer bolts, still need a couple more mm spacing though so the carrier sits in the middle of the disc, as it stands if i do the carrier up tight it locks the disc solid so little bit more playing about needed
havent dont much to the car for a long time to be honest, still need to get the block out so i can send that away, still need to take the dash back out to i can pull the loom out
cant make up my mind whether to get the dash flocked or not while its out
also still pulling all the old abs crap off and still hunting sierra rear callipers to get started on the rear disc conversion aswell
once ive finished building this ill have more time for the s2 which i really cant wait for
A.t.p
Oct 23, 2015 07:54 PM
AJC
Oct 8, 2015 11:09 AM
Kiran1600E
11
Oct 2, 2015 11:35 AM
SMILER258
Sep 28, 2015 09:04 AM
