Remote Oil Filter Help
Old Oct 17, 2012 | 01:49 PM
joffy's Avatar
joffy
SLOW LEARNER
Default Remote Oil Filter Help
Fitting a remote oil filter setup on the 3dr as space is tight and also it makes changing the filter easier. Ive ordered the remote housing and the take off plate but a couple of questions have come up,
1, Does it matter at what height you mount the filter? Ie if you mount it to high will it drain out etc?
2, Is -10 hose a big enough bore?
Thanks in advance
Old Oct 17, 2012 | 02:34 PM
M K's Avatar
M K
-10 Hose is fine for the oil lines
It does not matter where you mount it as the oil system is pressurised, I'd keep it
Low and in the clearest area you can though to make changing the filter easier, and out of harms way,
Also make sure you plumb the feed and return the correct way in the remote housing,
Just mounted mine a while back, not done the lines yet though
Old Oct 17, 2012 | 02:51 PM
Sonic Boom's Avatar
Sonic Boom
I used -10 on my 3 Door here's how I mounted it:
Rich
Old Oct 17, 2012 | 02:53 PM
joffy's Avatar
joffy
SLOW LEARNER
Nice one, cheers guys,
Old Oct 17, 2012 | 03:00 PM
lacey's Avatar
lacey
Also if you have a Mocal one then port it as the internal detail is not the best , pace ones are good , and I will have my own ones on the Market soon , also use swept fittings rather than compacts
Old Oct 17, 2012 | 03:01 PM
joffy's Avatar
joffy
SLOW LEARNER
can you explain swept and compact fittings please?
Old Oct 17, 2012 | 05:14 PM
Sonic Boom's Avatar
Sonic Boom
Swept fitting are the ones fitted to my 3 Door as above.
My remote oil filter housing is one from Torques which I can highly recommend.
Rich
Old Oct 17, 2012 | 05:57 PM
lacey's Avatar
lacey
Think auto are also good for fittings and hose + more
Old Oct 17, 2012 | 07:23 PM
Cosnada's Avatar
Cosnada
I have heard that the Pinto / YB like to have their coolers mounted upside down. It was explained that it works better with the natural pulses from the oil pump.
Now, this came from a very experienced YB engine builder on another forum. I don't want to sound like the obligatory pub talker putting in his 2p worth - was a genuine comment at the time from the guy.
Maybe someone can confirm / deny this?
Just spotted Rich has done it lol
Old Oct 17, 2012 | 08:04 PM
lacey's Avatar
lacey
All pumps pulse that all to do with how many lobes/teeth on the pumps inner and outter rotars, as for the mounting of a oil cooler , you want the oil to use all of the cooler , and having a bigger cooler does not always mean it will cool better , in some installs 2 small ones work better
Old Oct 17, 2012 | 09:03 PM
stevieturbo's Avatar
stevieturbo
C**t
Just mount the filter in such a way oil wont pish everywhere when you go to change it ! lol
Not like some numpties who mount the bloody filters upside down. Almost all filters have anti-drain back valves in them anyway so during normal operation they will be fine.
And as mentioned ensure you get the flow path through the filter correct. Not all housings are the same.
Old Oct 18, 2012 | 07:45 AM
joffy's Avatar
joffy
SLOW LEARNER
Thats part of the reason im moving it so it doesnt piss oil down the side of the block and the steering rack etc
Just checked and all the fitting ive got are swept ones from torques or merlin motorsport,
cheers for your help
Old Oct 18, 2012 | 04:16 PM
andy escos's Avatar
andy escos
not sure if any of what you said is true but the reason most people fit the cooler upside down is when they change there oil it will drain down by it self if it was up the other way you would have to take the cooler off every time to empty it every time you change the oil to drain the cooler .
Old Oct 19, 2012 | 08:14 AM
moomblue's Avatar
moomblue
sounds great
Cheap Wedding Dresses
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
