Difference between the Focus Mk2 RS and the ST 2.5 engine
Old Oct 15, 2012 | 02:22 PM
Trevor82012's Avatar
Trevor82012
Default Difference between the Focus Mk2 RS and the ST 2.5 engine
Good day to all,
Can anyone advise the differences between the 2.5 engine in the Focus Mk2 RS and the Focus Mk2 ST.
Any comments is much appreciated.
Old Oct 15, 2012 | 03:44 PM
2001ode's Avatar
2001ode
Engine block, pistons, connecting rod, camshaft (inlet only I believe) flywheel, clutch, injectors.
Claude.
Old Oct 15, 2012 | 05:02 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
St runs higher compression than the rs and also they have different turbos
Old Oct 16, 2012 | 02:18 PM
Trevor82012
Thank for the info. I did not think the bottom end was different. I was thinking cams, turbo and injectors.
Cheers!!
Old Oct 16, 2012 | 11:42 PM
CosworthGuy
3dr Cosworth owner
The st bottom end is quite weak im led to believe. You can buy a girdle from jamsport i believe for the block. Im sure this doesnt stop the liner issues though
Old Oct 18, 2012 | 02:05 AM
Trevor82012
What liner issue. therefore I should autocrossing it.
Old Oct 18, 2012 | 06:37 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Common for ST's to crack the liners, has happened to both standard and modified ST's.
Old Oct 18, 2012 | 06:41 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
As above, IIRC the exhaust cam is the same.
The RS had a re-work on the block to stop cracked liners, few people seem to know what was done, but it's been around for yonks with the Volvo boys!
Old Oct 18, 2012 | 08:22 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
A friend of mine in the automotive manufacturing trade told me that Ford "Value Engineered" the Volvo engine when they started using it, one thing was reducing the liner thickness. This has obviously had a detrimental effect.
Old Oct 19, 2012 | 12:05 PM
Trevor82012
Dam! does this mean that my high oil temperatures means, I have a cracked liner.
Old Oct 19, 2012 | 12:09 PM
Trevor82012
Oil temperature goes up when driving hard. and in turn the water temp. goes up also. I am hoping the Oil cooler is failing. This is an easier fix.
If its the liner, any one knows where I can get RS liners.
Old Oct 25, 2012 | 12:41 PM
sas's Avatar
sas
should be good!
When racing my RS mk2 this year I would run with 110 deg C water and 130 deg C oil. Car still runs fine.
Old Oct 25, 2012 | 12:52 PM
martysmartie's Avatar
martysmartie
Is the RS block not "plasma lined"?
Martin
Old Oct 25, 2012 | 02:19 PM
Paynee's Avatar
Paynee
Am i right in thinking that the later ST's (around 08 onward) have had adjustments made to overcome this aswell as the RS engines, sure i have read this somewhere online. Although dont believe everything you read on the net!
Old Oct 25, 2012 | 06:10 PM
sas's Avatar
sas
should be good!
The plasma coated liners are a new take on honing. In stead of the oil sticking to the block wall in small scores, it now sit on a porous "plasma" coating.
Old Dec 22, 2014 | 09:38 AM
knight7660's Avatar
knight7660
Also the RS engine uses a forged crank rods and Pistons from what I've read
Old Dec 22, 2014 | 05:14 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
I think he would of learned what's what after the two years he posted it
Old Dec 24, 2014 | 05:48 PM
knight7660's Avatar
knight7660
�� I always forget to check the thread date lol I hope he has learnt aswell
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
taylora1409
Aug 12, 2015 12:06 PM
kyle_st200
Ford Focus (All Models)
Aug 7, 2015 06:06 PM
