blacktop zetec air con removal
Old Oct 15, 2012 | 12:20 PM
zetecturbo12's Avatar
zetecturbo12
Default blacktop zetec air con removal
hi all i have a 2.0 blacktop zetec in my focus the air con is broken i want to take it out completely but need to know what belt i can use in place of the one thats there?
Old Oct 15, 2012 | 12:38 PM
phil_focus's Avatar
phil_focus
I believe you can get a shorter one off a non air con model either 1.8 or 2l.
Ask at your local motor factors as they will be able to do a search on their system under make, model, year, engine and air con option.
Old Oct 15, 2012 | 01:27 PM
zetecturbo12
have tried that and apparently it wont fit will have to take it off and run some string around to find length thanks
Old Oct 15, 2012 | 04:10 PM
black_jack's Avatar
black_jack
Black Jack
I did mine on my Car, ordered several belts online - they were all wrong - measured it with string and got it from local motor factors
the AC pump weighed 7kgs and the "radiator" 4kgs 11kgs does not sound much but it adds up and the AC pulley spins at crank speed so its like taking that weight off the crank
the engine should pick up and rev through the (power) band quicker (especially in the lower gears) and the little bit less weight forward of the front wheels made a surprising difference to the turn-in (steering/ handling)
watch your traction - i would take a bit off the back (behind the wheels) to compensate on a FWD car
i would cut (hacksaw) the AC lines inside the engine bay as they go through the bulkhead and maintain the seal in the heater, leaving the "matrix" part of the AC system inside the "heater" box i damaged mine and allowed refrigerant into the cabin - not nice - and the heater box is a nightmare to get out
i ripped out the rest of the AC system
im fitting an electric water pump (electronically controlled) now, - no parasitic loads for the AC or warterpump and the alternator and power steering are run at stock speed (no potential problems that may have happened with an underdrive pulley)
Old Oct 15, 2012 | 06:15 PM
zetecturbo12
Thats great thanks
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
hopper350
Sep 4, 2015 12:53 AM
Aug 29, 2015 08:16 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
