2.0 dohc engine convert to carb
Old Oct 14, 2012 | 06:50 PM
tonysierra4x4's Avatar
tonysierra4x4
Default 2.0 dohc engine convert to carb
does anyone know if it is possible, or has anyone converted a dohc engine fitted to later sierra models and others, to run carbs. the only reason i would like to know is the plenum sits very close to the bonnet not allowing a strut brace to be fitted. is there another way to run injection on them without the large plenum, ie a different plenum with less height. could just not fit brace but want to explore all options first.
Old Oct 14, 2012 | 06:57 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
DOHC converted to run a carb?
really?
yes ford put them in sierras and sold shitloads of them
they are non-injected sierras without holes in the head and port shapes changed as they had no injectors
easy peasy!
Old Oct 14, 2012 | 07:07 PM
Cossie Sean
here you go fella
8v engine Specifications
Two valves per cylinder with hydraulic valve lifters
Twin camshafts driving by a timing chain
Stroke and bore were both 86 mm (3.4 in)
Compression was 10.3:1 (Later versions of the 8V DOHC were 9.8:1)
Five main crankshaft bearings
N8A
Carbureted
Power: 107 hp (80 kW) at 5600 rpm.
Torque: 174 Nˇm (128 lbˇft) at 3000 rpm.
Redline: 6050 rpm
Will try to find some pictures too.
Sean.
p.s normally find these in low spec estates for some reason?!
clyde 1800's Avatar
clyde 1800
a carb hasnt nearly even the same power as an injection set up i would advise getting an engineer to muck up a strut brace to go front and back of the engine this will be a much simpler cheaper option imo
Old Oct 14, 2012 | 07:09 PM
clyde 1800's Avatar
clyde 1800
Originally Posted by Cossie Sean
here you go fella
N8A
Carbureted
Redline: 6050 rpm
Sean.
are you saying there was 2 different types of injection engines?
an early one and a later one?
Old Oct 14, 2012 | 07:17 PM
Cossie Sean
yes, AND a carb engine from Ford.
didnt have holes in the head or ports for injectors
manual fuel pump on the block
Ben26
Aug 27, 2015 08:56 PM
Toms Grende
13
Aug 22, 2015 03:39 PM
