Car running hot. Critically need help!!
Old Oct 10, 2012 | 09:13 PM
Jopro24's Avatar
Jopro24
Default Car running hot. Critically need help!!
My 2004 ford focus 2.0L dohc. Is running hot. I've done all I know to do changed water pump thermostat and housing used stop leak. It's no longer leaking water at all but the car is still running hot when sitting still the fans work as long as the a/c is on so I don't know what else to do. Water level is consistent im out of ideas. Please help this is my wife's car and it is impossible to live with one vehicle.
Old Oct 13, 2012 | 11:05 PM
tommytwotanks's Avatar
tommytwotanks
have you tried flushing the radiator out as it may be blocked
Old Oct 13, 2012 | 11:15 PM
botters's Avatar
botters
competant bodger
did you bleed it correctley after doing the above?
Old Oct 15, 2012 | 09:14 PM
chuckfinlay's Avatar
chuckfinlay
Using stop leak can block the rad, a way to check is to feel both the upper and lower hoses to see what temperature they are (should be fairly similar) Another way if you can get access is to feel the temp of the rad, the core should be same all over.
Adam-M
22
Aug 10, 2015 10:46 AM
Zoggon
Aug 10, 2015 10:39 AM
yawiejon
15
Aug 9, 2015 06:36 PM
vdubo7
Aug 2, 2015 08:17 PM
BMROVAL
Shows & Track Days
Jul 31, 2015 05:32 PM
