Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Fiesta discharging battery?
Old Oct 8, 2012 | 12:32 PM
smarttee's Avatar
smarttee
Default Fiesta discharging battery?
Hi, can anyone help please?
positve side battery dischaging to earth, battery flat overnight.
3 leads connected all red and thick gauge , one goes to starter, and the others I presume go to relay box, bulkhead passenger side in engine bay. had problems with starter motor but bought second hand one.
has onyone a drawing? please
thankyyou
Old Oct 8, 2012 | 01:04 PM
JOHNDQ's Avatar
JOHNDQ
You need a amp clamp really to find that mate if not could use a muti-meter between battery and the live term! Try removing live from alternator maybe windings have gone to earth
Old Oct 10, 2012 | 05:27 PM
smarttee's Avatar
smarttee
thank you, will try that with my multi meter in line.
Old Oct 10, 2012 | 06:20 PM
JOHNDQ's Avatar
JOHNDQ
No probs
Old Oct 10, 2012 | 06:55 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
You sure its not just a shit battery and not holding its charge?
Old Oct 10, 2012 | 11:16 PM
smarttee's Avatar
smarttee
yes am sure, have had positive lead disconnected for a day, as there is a o.3amp discarge , however i still think it could be the secondhand starter i bought.although a wiring diagram would help considerably
Old Oct 11, 2012 | 12:40 PM
martysmartie's Avatar
martysmartie
.3 of an amp is a "Parasitic" drain?
Martin
Old Oct 11, 2012 | 04:40 PM
smarttee's Avatar
smarttee
must be the used starter dragging battery down, but sometimes the spark is not at plugs?
changed coil pack, and flywheel sensor but no difference! just started the engine twice no problem then third time engine kept turning and turning
what does the ECU do? i thought it maybe the immobiliser but seems to work ok
Old Oct 11, 2012 | 07:51 PM
martysmartie
No, I would say the reading you mention is nominal.
ECU = electronic control unit and basically manages the engine, amongst other things.
Are you plugs/leads decent?
Martin
Old Oct 11, 2012 | 10:27 PM
JOHNDQ's Avatar
JOHNDQ
If the starters draws to much current things will shut down i.e you need around 8volts to hold a relay open
Old Oct 11, 2012 | 10:47 PM
smarttee's Avatar
smarttee
ah, now that makes good sense. as have no problem starting rolling down the smallest of gradients . thank you. will try another starter motor tomorrow
Old Oct 11, 2012 | 10:50 PM
smarttee's Avatar
smarttee
well i have access to a spare car so will try those leads before i change the starter motor. thank you,
Old Nov 26, 2012 | 04:59 PM
Archer14's Avatar
Archer14
I remember It also happens to me when i have that car. The battery was draining overnight. I checked that I had not left any lights on or anything. But I found the problem which is my car audio player. the memory circuit was draining the battery, then I change the audio system and it never happens again.
Old Dec 22, 2012 | 01:05 PM
Brendan's Avatar
Brendan
struggling with reality
you can get a current testor that sits where the fuses go cheaply from maplins this will tell you which circuit is draining the battery!
Nov 1, 2015 06:53 PM
sridgett
Oct 1, 2015 07:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
