mk1 focus mystery no power under load/forward gears
Bit of a mystery with a recently bought mk1 03 Focus 1600
After low fuel light came on I parked it up and on restarting it had no power in forward gears then wouldn't start at all so put a can of petrol in gauge read just under a quarter full .
RAC diagnosed it to be coil but after cleaning plugs and a little fiddle with the cam sensor lead it started and ticked over fine on 800 revs though temp gauge came up to half pretty quick (after 4 mins)
though started still total loss of power when in gear / pull away, though fine in reverse.
RAC "richard" (lovely bloke) put a new coil on to try that and no joy so put old one back on. ended up towing.
He did say pos ECT sensor but also said that the whole thing seemed "very strange" as diagnostics was saying coil
started 1ST time this morning but seemed to have a lot of "condensation" (thoughts went to head gasket) coming out of exhaust. so checked water level and clour and everything seemed fine
any answers would be greatly appreciated
Maybe something like the VSS if it seems fine going backwards? Have you really tried booting it backwards to see if it totally fine when reversing?
Also you mention it was low on fuel so I would think about looking at changing the fuel filter (relatively cheap about £12 for Ford although since I last bought one might be about £32 now lol). Blocked cat would also caused above issues if running lean but strange as to why it won't do it when reversing...
Does it rev clean when in neutral?
YEP.......... You try to pull away and even giving it loads of revs it just dies tryed it in 1st and second and even down hill in just stalls but fllies backwards no probs. I recognise reverse is a lower gear so less load but most mysterious. RAC Richard gave it 2 and half hours of his time and was left a little gutted he hadnt managed to at least work out what the prob was
shame as first go in a focus and was loving it (have only had it 2 days)
Can't be anything too serious then.
There's a plug on top of the gearbox that houses the vehicle speed sensor as pani described,maybe worth unplugging that first and trying it again.
Honestly is the weirdest fault I've heard in sometime!!!
THANKS FOR THAT
have not given it a really good blast in reverse/ not much space but i get the feeling it might die if i give it too much but will go out now and try on hand brake to see if wheels start to spin
Yeah i thought also about fuel filter as it had been standing before i bought it as well as i was low on fuel (got a £20 quote).
interesting you mentioned the CAT as there seems to be a relatively new sensor on the exhauste near the cat on up pipe to engine Richard Googbloke (RAC) SAID THIS WAS SUSPICIOUS AS MIGHT HAVE HAD A PROB THEY MIGHT NOT HAVE FOUND
I second the blocked fuel filter personally although that doesn't andwer why diagnostics pointed to coil. Its worth checking the plugs are in good nick and set to the right gaps, colour will also indicate if its running rich etc. If the car is more than 10 years old and on original leads it would be worth changing them too as they will be passed their best.
RAC Richard stuck new leads and coil and no joy he also took plugs out and said they looked fine / a good make and newish (car has full service history on 160,000 miles)
what do you think on directing me to the ECT sensor I think he was scratching his head on the temp gauge coming up to half so quick. (was wondering if there was more than one fault going on)
would this sensor effect the power to a big degree
CHEERS FOR THAT
manual and all gears seem very posative infact when i bought it the gearbox was a real positive, i really like the feel of it though the bight on the clutch is quite a way up i prefer in on the floor me self, slight race bearing noise but nothing drastic and no shuder when it was working so it seems a power issue though this SPEED SENSOR seems interesting no idea it had one of those in fact the whole car seems covered in them (03 IS A NEW CAR FOR ME )..........THE NEW FORD SENSOR
CHEERS WILL DO ...off out in the rain now REALLY WANT TO GET IT GOING AS SO IMPRESSED WITH IT, FOR 2 DAYS AT LEAST ............got me enjoying Ford again!
ECT shouldn't limit the power at all unless things are wrong and it goes into limp home mode. I wonder if this is the case?
I parcially blocked fuel filter can leave the engine revving fine under no load but restrict fuel flow enough to cause power loss and stalling under load. Depends how bad it is but that would be the next thing to replace and at 160,000 if its still on the original filter then it definately NEEDS replacing!
Blocked cat or blocked fuel filter show similar kind of symptoms. As said fuel filter is relatively cheap to change over but cat you can test by getting it up in the air and using an IR temp gun to check the temperature its getting up to. If you can't do that, check to see how well the exhaust is blowing whilst someone revs it.
If it revs lethargically or has a flat spot then it is definitely something like fuel filter or possible lambdas and/or cat needs looking at. Temperature probe shouldn't have much to do with the issues you are describing.
CHEERS FOR THAT ok will replace filter and go from there (tick down the list and not to expensive) will post if it works, cheers again!
ahhhhhh limp home mode......... what if i disconnect batt / try resetting . have not done that yet though would RAC have done that on their lap top
Disconnecting the battery won't hurt and will make the ECU re-learn next time it is connected although if it is an underlying problem it won't make any difference. Be sure to have the radio code though!
Exhaust is blowing quite white when cold but have been told most likely condensation as pressure over oil cap and colour of water not hinting at head gasket.
Seems to be revving fine , very smooth in fact and a very quite engine to what im use to even after 160,000
oh have noticed very small whole in exhaust between back boxes other than that exhaust seems fine infact where the cat is it looks new (maybe privious had problems and tried replacing cat) ummmmmmmmmmm the more i look the more the mind wonders WHATS THE STORY ?
CHEERS, yep got the code
ah yes it might have gone on to limp mode but what caused it to do that ? would blocked fuel flow have caused it to go into limp
reading back through seems like fuel filter is the place to go, and go from there
My ST had a similar problem, lost power through the rev range although it ticked over just fine with no sign of a mis-fire. My diagnostics sofware came up with MAP sensor, put a new one in and all was good again. I'm pretty sure yours will have this MAP sensor rather than a MAF that the earlier ones had. Could be worth looking at.
check the breather hose that runs from the block breather under exhaust manifold around the back of the engine onto inlet manifold - very prone to perishing or just falling off causing an air leak and leading to symtoms you describe. also when it happens it throws up the code for the lambda sensor whick may explain why yours looks new
OK seems like air is getting in judging by the exhaust or something is messing with the mix. Also starts popping when reverse is pushed.
Have just got fuel filter though so will stick that on regardless .
Have got a £85 quote for MAP sensor so off down breakers tomorrow for that (yes its a budget job) STILL CAN NOT LOCATE THOUGH any ideas?
Should be plugged into the inlet manifold somewhere I would've thought or somewhere in the induction pipework? This is all near the front of the engine as the sigma engines have the inlet at the front.
Just a thought that might be worth trying.
Stick a lot more fuel in it before spending too much on faults. Had similar years ago on the vauxhalls, if you ran them out of fuel they'd not run right if you just stuck a can in, even though you'd have been ok running them about with that much in. Most tanks have a baffled area where the sock on the pump sits and you need to get a decent amount in.
Might just be that as you go forward e fuel is moving away from the pump (if it's at the front) and if you go backwards the fuel feeds the pump easier.
Might be worht a shot. We used to have to a third of a tank back in the old vauxhalls if they ran out.
CHEERS FOR THAT JAMES
Will give it a go
I did notice that not a great deal of fuel came out when i changed the filter not sure if that ties into what you suggest
Starting to feel a little pessimistic now as have just noticed the top fixing on radiator is missing (radiator moves quite away back on bottom fixings only) which is pulling me back to head gasket as it might have started overheating for previous owners) Shame if I have to scrap it as I was thinking this is such an improvement on my last car MK3 GOLF (which i still have)
Though there is a nice set of alloys on the focus which i should get something for I guess
Will give it a go
Have finally located the map sensor YES
stuck to the side of the inlet manifold behind the alternator.
Whist getting alternator off noticed a coroded central pin which has now broken off has made me wonder if enough elec was getting to the spark plugs but anyways the map sensor was rank so cleaned off and will try tommorrow if no joy with that will try a new one but now need an alternator connection which prob means a whole alternator but hay ho now feel like im getting somewhere
the battery needs to be a silver calcium one as the focus has smart charge which will kill a normal battery in no time. I doubt it will be causing your fault but worth getting the right one put on!
Oct 9, 2015 07:38 PM
saph in dorset
Aug 14, 2015 10:10 AM
