Cosworth inlet manifold
Old Sep 26, 2012 | 03:03 PM
scholes's Avatar
scholes
Default Cosworth inlet manifold
Hi ppl
I have got a small turbo escos inlet and wanna no if I can make this work with l8 ecu as the tps are diffrent
Old Sep 26, 2012 | 03:42 PM
andy escos's Avatar
andy escos
just fit the 4x4 throttle body bolts straight on
Old Sep 26, 2012 | 06:05 PM
scholes's Avatar
scholes
Isn't that defeting the object as the tb is smaller ?
Old Sep 26, 2012 | 06:52 PM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
is there a difference between then? I though all the inlet trumpets are the same and the plenum cover and TB are different between a 2wd, 4x4 ( saff & escos) and 500?
Old Sep 26, 2012 | 07:05 PM
scholes's Avatar
scholes
all plenums are slightly diffrent but the small turbo escos uses a bigger tb
Old Sep 26, 2012 | 07:13 PM
andy escos's Avatar
andy escos
yes it is smaller than the small turbo throttle body but unless your after more than 650hp then the 4x4 one is fine as thats what it will flow.
Derek Burleigh
Sep 16, 2015 06:27 PM
Russ Hill
Aug 31, 2015 06:44 PM
Anutternutter
Aug 21, 2015 06:07 PM
Bailes1992
Aug 16, 2015 07:14 PM
mick pearson
Aug 9, 2015 09:19 AM
