Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
rs2000/st170
Old Sep 23, 2012 | 03:48 PM
tezzer's Avatar
tezzer
Default rs2000/st170
anyone know whats involved in fitting a focus st170 dura-tec engine into mk6 escort rs4x4?? i would like to run it on bike carbs, any info welcome, thanks
terry
Old Sep 23, 2012 | 04:03 PM
Mark_'s Avatar
Mark_
terry
Jump on www.rs2000-16v.com
Great site with loads of info on there. You can keep the rs2000 lump and use bike bodies.
Its been done loads with good results
Old Sep 23, 2012 | 04:14 PM
tezzer's Avatar
tezzer
thanks mark, not long had this rs, suffering from idle problems, done all normal things, my idea was to fit the bike carbs to my rs engine, to get it running better, but im looking at upgrading the bhp at a later date and thought the easiest way would be to fit the focus 170 with perhaps a pair of better cams etc. forgot to say it's 4x4.
terry
Old Sep 23, 2012 | 05:36 PM
Mark_'s Avatar
Mark_
Check the wiring to the coil packs as they ALL deteriorate and cause all sorts of running probs.
move the wires whilst its running and listen for a change. Quite often causes the car to run on 2 cyclinders. I'd consider replacing it either way as it will cause problems sooner or later.
Old Sep 23, 2012 | 07:58 PM
tezzer's Avatar
tezzer
where can i buy new wiring for the coil packs? had a quick look but haven't found any yet, found coil packs but not loom wiring.
Old Sep 24, 2012 | 03:23 PM
Mark_'s Avatar
Mark_
You have to make it, There is a guide on the rs2000 site.
Its really easy and will cost less than £10
Old Sep 24, 2012 | 03:52 PM
tezzer's Avatar
tezzer
Thanks mark, I will order the parts tomorrow,
Terry
