rs2000/st170
anyone know whats involved in fitting a focus st170 dura-tec engine into mk6 escort rs4x4?? i would like to run it on bike carbs, any info welcome, thanks
terry |
Originally Posted by tezzer
(Post 6046593)
terry Jump on www.rs2000-16v.com Great site with loads of info on there. You can keep the rs2000 lump and use bike bodies. Its been done loads with good results |
Originally Posted by Mark_
(Post 6046605)
Great site with loads of info on there. You can keep the rs2000 lump and use bike bodies. Its been done loads with good results terry |
Check the wiring to the coil packs as they ALL deteriorate and cause all sorts of running probs.
move the wires whilst its running and listen for a change. Quite often causes the car to run on 2 cyclinders. I'd consider replacing it either way as it will cause problems sooner or later. |
(Post 6046727)
(Post 6046923)
where can i buy new wiring for the coil packs? had a quick look but haven't found any yet, found coil packs but not loom wiring.
You have to make it, There is a guide on the rs2000 site. Its really easy and will cost less than £10 |
Thanks mark, I will order the parts tomorrow,
Terry |
© 2024 MH Sub I, LLC dba Internet Brands
