central locking problem
Old Sep 17, 2012 | 09:27 AM
iwols's Avatar
iwols
Default central locking problem
hi guys can anyone help with a problem on my 02 tdci mondeo please,when i press the locking button on my remote i hear a noise from the doors but none of the door latches move and the doors dont lock,when i use the key it will lock the drivers door but none of the other three,ive heard of the problem where the doors lock but after a second they open again but not the fault i have thanks guys
Old Sep 17, 2012 | 09:29 AM
RichieST's Avatar
RichieST
It'll most likely be the drivers door lock mechanism that's failed. Very common fault on the mondeos, I've recently had to do mine!
Old Sep 17, 2012 | 09:31 AM
iwols's Avatar
iwols
thanks for that,would this stop the other doors locking for a split second
Old Sep 17, 2012 | 09:43 AM
iwols's Avatar
iwols
and the doors will unlock after i have manually locked them does this make sense still?,what parts in the door fail or is it usually a wd40 job thanks again
Old Sep 17, 2012 | 12:31 PM
RichieST's Avatar
RichieST
The drivers door module controls all the other doors, when water gets in to it it can do all sorts of funny things. On mine the left rear door would not lock / unlock, they would ping straight open when using the remote and would sometimes lock / unlock themselves when driving along. hanged the drivers door unit and it sorted it. I'm not saying this is definately the part that has failed on yours but the symptoms sound like it and as said, it's a common failure on the mondeo!
This is the part you will need.
http://www.ebay.co.uk/itm/FORD-MONDE...item5ae9959abb
Old Sep 17, 2012 | 06:15 PM
iwols's Avatar
iwols
Thanks Richie but does this include the module
Old Sep 17, 2012 | 06:58 PM
RichieST's Avatar
RichieST
Yes it is, it's all contained within the door lock / motor unit. When you tke your old one out, it's easiest to swap the handle sections over as you will need your original lock barrell. It is quite a fiddly job but pretty self explanatory once your doing the job. When I did mine the other day it took about 45 mins!
Old Sep 17, 2012 | 07:10 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you could always have asked me
http://www.talkford.com/topic/131866...ide-door-lock/
Old Sep 17, 2012 | 11:01 PM
iwols's Avatar
iwols
thanls guys
Old Sep 18, 2012 | 10:55 PM
iwols's Avatar
iwols
took car to garage tonight and they changed all units one by one and still doing same any more ides plz
stephenb4506
33
Oct 2, 2015 06:25 PM
DAZZER
Sep 30, 2015 08:43 PM
rsguy
44
Sep 29, 2015 03:29 PM
