EFI Conversion Problem.. No Spark!!
Old Sep 16, 2012 | 01:28 PM
Stolton's Avatar
Stolton
Default EFI Conversion Problem.. No Spark!!
Hello everyone
Ive just finished the EFI conversion on my Series 2 Escort RS Turbo. Im using OFAB Loom & ECU and a 36-1 Trigger Wheel setup for the CPS.
The problem i have is that i cant get a spark for love or money. Everything is connected properlly, got ignition, turns over well and have fuel getting to the injectors etc
Ive tryed different ECU, Coil Pack, Leads, MAP Sensor, Map Supressor, EDIS, CPS but still nothing.
It doesnt even seem to cough or splutter it just keeps turning over.
I know the loom and ecu is good because it came out of my mates running car, also i have checked all the sensors to make sure there working correctly and checked the resistance of each sensor plug
Can anyone help?
Thanks
Old Sep 17, 2012 | 03:49 PM
Stolton's Avatar
Stolton
Anyone..?
Old Sep 17, 2012 | 03:57 PM
Pudnpepsi's Avatar
Pudnpepsi
Fix or repair daily....
checked for live at pin one on ecu? have you got a pulse on the two outer wires on the coil pack? are there good earths? is the ignition live in the centre of the CPack live whilst cranking?
Old Sep 17, 2012 | 04:16 PM
frsjon's Avatar
frsjon
when you say a 36-1 wheel is this instead of a frst flywheel? check the distance from the sensor to the pulley is 110% spot on
Old Sep 17, 2012 | 10:27 PM
Stolton's Avatar
Stolton
Yes mate have live at pin 1. Have a pulse on both green wires going to the coil as you say the two out ones. Yes i have good earths and ignition live is the centre wire which is showing correctly.
Old Sep 17, 2012 | 10:29 PM
Stolton's Avatar
Stolton
Yes Jon. The Trigger kit is set up spot on with the correct gap on the CPS and the CPS picks up the missing the tooth when at 90degrees BTDC
Old Sep 18, 2012 | 07:02 AM
Pudnpepsi's Avatar
Pudnpepsi
can you check the ecu has live whilst cranking? as that is million miles from ignition live....
Old Sep 18, 2012 | 07:03 AM
Pudnpepsi's Avatar
Pudnpepsi
*ign live whilst cranking
Old Sep 18, 2012 | 07:40 AM
Stolton's Avatar
Stolton
I will give it ago mate later on today after work. Its sending me mad and i dont know what else to check lol i was thinking of trying to get hold of a Oscilloscope to go into more depth with the wiring..
Old Sep 18, 2012 | 09:28 AM
gup's Avatar
gup
Have you plugged your speed sensor wire in ontop of the g/b
Old Sep 18, 2012 | 09:46 AM
Stolton's Avatar
Stolton
No i havent gup as i was told i didnt need to. Was i told correct?
Old Sep 18, 2012 | 12:56 PM
gup's Avatar
gup
When I converted my van to ofac, it wouldn't start due to the g/ b sensor, plugged it in and it fired up on the button
If you look on a wiring diagram it goes to the Injectors and the coil iirmc only thier to raise the idle speed when slowing down to stop it stalling
Old Sep 18, 2012 | 01:13 PM
Stolton's Avatar
Stolton
Ok mate will give it a try and see what happens
Old Sep 18, 2012 | 04:01 PM
Pudnpepsi's Avatar
Pudnpepsi
As gup said. you need to run a VSS, else it will die at junctions...
Old Sep 18, 2012 | 04:44 PM
Stolton's Avatar
Stolton
But surely that wouldnt stop it from not sparking?
Old Sep 19, 2012 | 11:52 PM
HirenRS's Avatar
HirenRS
turbovh
Default spark
the g/box plug on top wont stop it sparking my rs was running years without it connected only one at front of box on lower half was connected whre bouts are ya my rs is in bits if u wanna test some of the bits on ures ofab aswell
Old Sep 19, 2012 | 11:59 PM
HirenRS's Avatar
HirenRS
turbovh
Default whoops
just ralised bournemouth!, im inherts sorry mate will try and asdsist however, if it was me i no u prop tested already i would check gapping, or even better i had same prop when my gaping was incorrect i used a fiat punto 55plate and extended my cps wire with a sensor on the end ran it close to the crank pulley on fiat with my ignition on and all plugs out to stop it starting or remove fuel pump fuse, i then saw a spark when i held it close by hand isnt modest i know but it worked as a good diagnostic test, als i would check all loom earths, coilpack, all igntion related wires and connectors, edis module i dod not use a trigger wheel but i wouldnt worry as all it is doing is the same as the efi flywheel 36/1 and sends an inital signal check everything agin and again, also the wires on the cps have to be right way round had problem with this previously aswell switch them over and give it ago first before doing anything
Old Sep 20, 2012 | 12:56 AM
Stolton's Avatar
Stolton
Ok mate thanks for that, i will be giving it another go after work tomorrow so will try a few more things but first i will change the wires on the cps..
Old Sep 20, 2012 | 06:56 PM
Stolton's Avatar
Stolton
Nope still nothing. The cps wiring was all good. Its got to the point now where ive lost all enthusiasm to sort it. Its a shame really because ive spent 8months doing bits to it and doing stuff i wanted to but now i might have to break it as its causing me such a headache i dont know what to do for the best
Old Sep 20, 2012 | 07:10 PM
HirenRS's Avatar
HirenRS
turbovh
keep at it youre ognna get it soon !
Old Sep 20, 2012 | 07:31 PM
1980blakey's Avatar
1980blakey
I had the same thing and it was the earth by the amal valve plug wasnt connected.
Old Sep 20, 2012 | 08:24 PM
Stolton's Avatar
Stolton
Ive tried everything that everyone has suggested and still no luck. Its so strange and the more i look at it the more it winds me up lol. I think its time to get a professional to sort the problem and get it running
Old Sep 21, 2012 | 02:56 PM
Stolton's Avatar
Stolton
You was right mate lol reason i didnt have it connected was because it was wrapped up in tape with the amal valve. So i unwrapped all the tape and found the wire which is the earth for the EDIS. Atleast it runs now but has a small missfire so im guessing it needs setting up properlly. Happy Days tho
Old Dec 10, 2013 | 10:09 PM
mattxr2's Avatar
mattxr2
iv got the same problem now! i have just fitted escort rs turbo engine into my mk2 fiesta and i have no spark there is live to the middle wire on the coil pack but both outer wires are pulsing lives instead of pulsing earths i have checked all sensor but the only sensor i dont have is an amal valve, and this is because i cant find one i have checked all my sensors and my cps 10000 times still no look has anyone had the same problem??
mk3ste
Oct 17, 2021 10:09 AM
Nov 1, 2015 06:53 PM
deathrider666
Sep 28, 2015 06:12 PM
SMILER258
Sep 28, 2015 09:04 AM
mpilk
Sep 27, 2015 09:21 AM
